Has anybody here built an engine with the Mopar Performance P5007494 Max Wedge heads?
I am interested in using these heads to build an engine for my truck to use in some local sled pulls. The rules state: "Engine size is 480 cubic inches with +/- 2% for pump accuracy. Engine block and heads must be cast iron. Must have OEM casting numbers." To meet this, I am considering building a 470 stroker using my truck's 400 block and using these max wedge heads and an Indy 400-2 4150 single plane intake manifold, which, to me, meets the rules.
This being said, I have not found much information on building these heads, or who can best set these up. I am looking for tips and advice on using these heads, and what work they need to set them up, as they come bare. I'm not wanting to spend a fortune, but want a solid foundation to work with.
