Slant Six 904 in truck #1036310
07/20/11 02:52 AM
07/20/11 02:52 AM
NORTHERN CA
HUSTLESTUFF Offline OP
NORTHERN CA
Will a car 904 fit into a pick up truck? I know there are different starter postions. I have a runnable car trans and a friend of a friend needs one in his truck. He is planning a swap from 318 4 speed to slant auto. Mike
Re: Slant Six 904 in truck [Re: HUSTLESTUFF] #1036311
07/20/11 08:58 AM
07/20/11 08:58 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I think it will work as long as they both are slants. He may have driveshaft issues going from 3 speed to 904.
Re: Slant Six 904 in truck [Re: buildanother] #1036312
07/20/11 09:09 AM
07/20/11 09:09 AM
scratchnfotraction Offline
yes,the 904 bolts right in the truck behind a 318
he will need a set of truck motor mount brackets and a rear sump oil pan,truck throttle pressure linkage rod to go with the 904..which are truck pieces only
may also need a longer drive shaft and smaller yoke
Re: Slant Six 904 in truck [Re: scratchnfotraction] #1036313
07/20/11 10:01 AM
07/20/11 10:01 AM
NORTHERN CA
NORTHERN CA
I think the slant is out of a truck and now that I think about it he has an auto now with the 318 so he'll stay auto, just 318 to slant 6. I told him about kickdown and we can make something work for that. Thanks, Mike
Re: Slant Six 904 in truck [Re: HUSTLESTUFF] #1036314
07/20/11 10:58 AM
07/20/11 10:58 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
will have to go /6 and transmission together. 318 transmission will not bolt up to the /6. /6 belhousing different. Belhousing takes care of starter location.
Re: Slant Six 904 in truck [Re: MoparforLife] #1036315
07/20/11 10:00 PM
07/20/11 10:00 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
A car slant six 904 will bolt up to a truck slant six engine as long as both engine and trans are '68-up or both are '67-down. Crank hub diameter and convertor snout register diameter changed in '68.
