Re: Police Diplomat
[Re: 67llite]
#1035985
07/19/11 04:37 PM
07/19/11 04:37 PM
Posts: 815 Alexandria, NJ
WayneM
Alexandria, NJ
What kind of '67 Plymouth do you have? In any event, it would be a shame to scrap a full boat (4 bbl/727/ skidplate) Police spec Dip unless it's a heap.
2014 Durango R/T 2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed 1998 Dodge Durango SLT 5.2 1971 Plymouth Duster- <<<<<MOPAR SPOKEN HERE>>>>>
Re: Police Diplomat
[Re: larrymopar360]
#1035987
07/19/11 05:11 PM
07/19/11 05:11 PM
WayneM
Alexandria, NJ
If It's a C body, I think the box is different.
Re: Police Diplomat
[Re: A38s!]
#1035990
07/19/11 10:55 PM
07/19/11 10:55 PM
Posts: 4,452 Michigan
MarkZ
Worthy
Worthy
Discs likely 10.87, not 11.75.
I agree, the A38/AHB M body cars had the same size rotors as the civilian variants. 11.75" rotors can be found on R body cars such as the Dodge St. Regis.
@67llite: If you are stripping a decent cop M, shame that it may be, there are a lot of parts you can sell to the F/J/M crowd. Grab the drive shaft, 8.25" rear, the front and rear sway bars, the rear shock plates, the 125MPH speedometer, additional coolers, and if it's a 4bbl car then get the kick down lever. These are all very desirable parts.
Re: Police Diplomat
[Re: 67llite]
#1035993
07/20/11 10:56 AM
07/20/11 10:56 AM
Posts: 1,160 Cruising!
QuickDodge
Cruising!
Will the 67 Pitman arm attach to the newer steering box? If not, what pitman arm is needed to make this swap work?
Police cars had different steering boxes. I had a 1983 and a 1986 Grand Fury Police cars. The steering box in the 1983 had MUCH better road feel. I do not know if the difference was due to the model year or if there were different police packages available.
My Grand Furys had the smaller disk brakes. I believe the brakes will bolt on to a 1967, but the spindle is taller, so it will change the geometry of the front end a bit. There has been a LOT of debate on whether or not this is a problem.
