SPUN BEARINGS
#1035939
07/19/11 02:29 PM
07/19/11 02:29 PM
Posts: 52 detroit mich
stevehiss
detroit mich
i spun a bearing ,can the rod be resized or is it junk, it doesn't look black but it did get warm
I DARE TO BE DIFFERENT
Re: SPUN BEARINGS
[Re: stevehiss]
#1035941
07/19/11 04:35 PM
07/19/11 04:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What brand rod
Re: SPUN BEARINGS
[Re: stevehiss]
#1035943
07/19/11 06:03 PM
07/19/11 06:03 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I will very rarely re-use a rod that has a spun bearing, even though it may look reconditionable. Can it be done? I suppose. Should it be done? No. As an example, often times when a rod or main spins on a crankshaft, it almost always induces enough heat to actually bend the crankshaft. It is often common to check a crank after either one of these failures and find from .003 - .006 runout or bend in the crank, and you can look at the crank and think it could have hardly been damaged. If its a stock rod, then I definately would NOT re-use it. An aftermarket Hbeam, well, much better chance, but you'll need to pull the dowel sleeves, re-size it and check the rod on a Sunnen or similar rod straightener for bend and twist....
RIP Monte Smith
Re: SPUN BEARINGS
[Re: stevehiss]
#1035945
07/20/11 03:17 AM
07/20/11 03:17 AM
Posts: 43,205 Bend,OR USA
Cab_Burge
I have had spun rods magged, resized and I reused them, that was a long time ago when racing money was really tight, houes payments, two kids in a christain school on a single income. I wouldn't do that now because to do it right you need to get the other seven resized so you can get the rod lengths within .002 of each other i have sen stock rods vary .008 in lengths in the same motors, must have been Monday or Friday motors don't forget that the heat treat is toast also so throw that expence into the decision making process BTW, what type and brand rod?
Re: SPUN BEARINGS
[Re: Cab_Burge]
#1035946
07/20/11 10:57 AM
07/20/11 10:57 AM
Posts: 7,506 Az
Crizila
Az
Don't mean to hi-jack, but what does everyone think are the most common causes of spun bearings?
Fastest 300
Re: SPUN BEARINGS
[Re: Crizila]
#1035947
07/20/11 11:42 AM
07/20/11 11:42 AM
Posts: 5,080 organ
maximum entropy
organ
improper crush, rod bolt issues, or lubrication. beyond that could be anything.
Re: SPUN BEARINGS
[Re: dogdays]
#1035949
07/20/11 01:19 PM
07/20/11 01:19 PM
Challenger 1
Cincinnati, Ohio
detonation ruptures the oil film and allows the vearing and crank to touch. R.
on rod bearings.
Re: SPUN BEARINGS
[Re: Crizila]
#1035951
07/20/11 02:29 PM
07/20/11 02:29 PM
Cab_Burge
Debis, rod elongation, improper fit of the bearing, to tight of clearnances, revving the motor to high on start up when cold before having oil pressure, same thing when hot, to thick of oil, the list is endless On clearances looser is better, cleanleaness is next to Godleaness when assembling motors, you can not keep them too clean
