Page 3 of 3 1 2 3
Re: build me a bad a$$ small block [Re: sixpackgut] #1035934
07/19/11 08:24 PM
07/19/11 08:24 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
na just comptetive thats all..
Re: build me a bad a$$ small block [Re: fishy340] #1035935
07/19/11 08:26 PM
07/19/11 08:26 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
thats cool
Re: build me a bad a$$ small block [Re: Mr.Yuck] #1035936
07/19/11 09:02 PM
07/19/11 09:02 PM
SoCal
Brian Hafliger Offline
SoCal
How about a 450cid, pump gas, Indy heads done by me, 1250 dominator, pump gas and around 700-720HP for about 15,500.00?
It won't be a street cam but it will make the power. 48° block, Charlies pan, etc....
Basicly our 800Hp build on pump gas and different cam.
Brian
that's a TON of money. WHy not just use a low compression 360 and a blower and be done for half? less cam, less stall and less gear required and you can DRIVE IT
I agree NA is not the best way to get that much power. But that wasn't the question. And that included Carb to pan, headers and belt drive.
It might be less, but I never quote low...makes for upset customers.
I'm involved with a customer of mine doing a Twin Turbo deal, RHS heads, hyd. roller cam that should make 700+ on pump gas with around 8-9psi and then we'll turn up the wick to about 14psi and see what happens.
He'll have about 12K in it including the Mega Squirt EFI!
Brian
Brian Hafliger
Re: build me a bad a$$ small block [Re: Brian Hafliger] #1035937
07/19/11 10:06 PM
07/19/11 10:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Brian
Brian
boost is the best way to go. 700 at 8 is good. w/ 12 lbs of boost you are really gonna push the numbers. You can get 700 all day w/ a BB e-heads and a 671. nothing fancy.
Re: build me a bad a$$ small block [Re: Mr.Yuck] #1035938
07/19/11 11:58 PM
07/19/11 11:58 PM
SoCal
SoCal
6-71 blower isn't as pump gas friendly as the newer stuff.
I don't disagree, but if you beef up the bottom end for the power, your gonna still have alot of money tied up in the build.
Brian Hafliger
Page 3 of 3 1 2 3
