build me a bad a$$ small block
#1035894
07/19/11 02:03 PM
07/19/11 02:03 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i want to know how much $$$ and what do i need to build a 440 ci small block?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: build me a bad a$$ small block
[Re: jim sciortino]
#1035896
07/19/11 02:15 PM
07/19/11 02:15 PM
sixpackgut
Charleston
I dont think it needs to be crazy expensive with w8s or 9s. maybe indy-1s.
pump gas combo around 700-750hp. what kind and size crank is needed to get that many cubes?
[Re: sixpackgut]
#1035897
07/19/11 02:40 PM
07/19/11 02:40 PM
sixpackgut
Charleston
ok, so by the lack of response, i take it that a 440 cube small block is not your basic cookie cutter small block
so, first thing i would like to know, is what type of block do you need to build this very large small block? what would be the bore and stroke?
[Re: sixpackgut]
#1035899
07/19/11 02:50 PM
07/19/11 02:50 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
I think a 4.125 crank like BPE sells at 4.100 bore should get you around 440 cubes.
If i was doing old school smallblock like that, i would probably use a 48 degree block and the 48 degree indy heads. good roller ,good headers, should be able to make 700 without a ton of effort.
could just as easily do it with a good X block at 4.100 bore as well with the 59 degree indy heads.Electric water pump, vacuum pump,electric fan, etc should be real doable.
Another way is to just by an r5p7 busch motor, run it on e85 and you are there as well, and WAY cheaper.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1035901
07/19/11 02:58 PM
07/19/11 02:58 PM
Posts: 1,019 Finland
mafo
Finland
I would go with the bigger bore if you want to use w8 or 9 heads, you just cant fit 2.20 intake valves in a 4.10 bore
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: sixpackgut]
#1035902
07/19/11 03:01 PM
07/19/11 03:01 PM
sixpackgut
Charleston
price check on aisle 3
indy sells a 440 short block 360-S7-440A
$4945
indy 360-1 kit is $3535
not sure if i want to go this route since i wouldnt use their pushrods or rockers.
do these heads need porting? how much would that add? would i want to do the 48 degree upgrade? i would think so, right?
[Re: mafo]
#1035905
07/19/11 03:17 PM
07/19/11 03:17 PM
B3422W5
Portage,michigan
Correct, that is why he said above he doesnt think it has to be a w8 or w9 deal. with an indy head 4.100 with a long crank would be fine.
If i wanted a bad [Edited by Moparts - Family Friendly Site - Keep it clean] small block on the cheap, it would be an r5p7 motor, can get a fresh, COMPLETE, and ready to run motor that will make 700 horsepower( likely more)easily for less than you can build an eddie headed 416 that would make 500 ponies, much less an indy headed deal you are going to have 15k in or more when all is said and done.
freind of mine locally did this exact thing and went 9.40's with the supplied belt driven water pump, and junk headers he fabbed up off a w2 motor. And it ran super cool at the track with even back to back laps. Drove it around on the street as well.No telling what it may have run had he played with it a little more than he did.
[Re: sixpackgut]
#1035906
07/19/11 03:19 PM
07/19/11 03:19 PM
sixpackgut
Charleston
ok, here is what i got
short block $4945 360-1 48* $4535 cam, lifters,shaft $1000 headers $750 carb $1000 oil system, cooling, balancer and dist & wires $2000
i'll port the heads and intake myself to save some cash.
will this do it? 700-750hp?
[Re: DragDart360]
#1035907
07/19/11 03:22 PM
07/19/11 03:22 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
48 degree is well worth a grand.
Sounds like you want a low RPM engine grunt engine.
[Re: sixpackgut]
#1035910
07/19/11 03:37 PM
07/19/11 03:37 PM
B3422W5
Portage,michigan
no, why do you say that? that is why i would choose the bigger bore over the stroke
that many inches even with an indy head is going to lower the power band down somewhat.my old w5 motor was pretty much done at 7000rpm even at 422 inches, i suspect it made peak power at about 6700-6800rpm. With pump gas you obviously will have a smaller camshaft than something with 13 or 14 to 1 compression. 440 inches on pump gas with indy heads should make its most power probably around 6500 imo.
[Re: B3422W5]
#1035911
07/19/11 03:48 PM
07/19/11 03:48 PM
sixpackgut
Charleston
Oh, i see what your saying. Hell, i saw a set of 360-1 heads on quicktrees motor and those ports looked huge to me. as a matter of fact, at a PRI show, quicktree started cracking up, and i was like what are you laughing at, he said look how small those bb ports are. he was pointing at EZ heads
anyone know how Quicktree is doing?
[Re: sixpackgut]
#1035912
07/19/11 03:50 PM
07/19/11 03:50 PM
Leon441
Lynchburg, VA
Your head choice.
And for what you are wanting to do that is about the best choice out. Strokers are great when you want to get it done with less RPM. You want some RPM build less stroke.
My choice would be 4.00" stroke and go for at least 4.125" bore.
