Re: big block VS small block
[Re: w7smallblock]
#1035639
07/23/11 10:48 PM
07/23/11 10:48 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
It's amazing that in 2011, people still don't understand important things, like "shift recovery" and "useable rpm".
It has nothing to do with....."my big block is better than your small block, or vice versa.
Pity, I tell ya.
You can talk to some people till your blue in the face and in the end all you got was blue in the face If they don't get it by now 2011 they will never get it and thats why most are still stuck thinking it's the 1970's with .590 cams and TRW pistons. If the last statement offends you then you are who I'm talking about.
It's called being "caught up in a time warp". But.. they ARE entitled to think that way and can refuse to "roll with the times", by choice. 1970's, 590 cams and TRW pistons? TWO parts of the previous statement, you can still buy today, BUT the '70's, you can never get BACK to!! FWIW, Do not waste time trying to "educate" those NOT willing to learn OR, at least, listen!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: d-150]
#1035643
07/23/11 11:28 PM
07/23/11 11:28 PM
HYPER8oSoNic
Desert Tracker
man i thought i was up to date building a full roller 360 but i must be missing something so please small block guys educate me
Got the "right" distributor drive/oil pump shaft, for that "race" roller cam? (for starters) Just common sense, I'm not an expert, neither a comedian (not at this instant). It's a serious question.
[Re: HYPER8oSoNic]
#1035647
07/23/11 11:50 PM
07/23/11 11:50 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Pity, I tell ya.
Hyper, No my 248* cam is not a solid. Its the old MP .509 I am stepping up to the MP .590 though with the new combo. Also #3000
And not to be left behind or caught up in the old time warp. Im going to test a modern comparable Comp cam. It does look much better on paper Im coming out of time warp, maybe.
[Re: steeldust]
#1035648
07/23/11 11:52 PM
07/23/11 11:52 PM
That's another thing, to get a decent tire on an a-body you have to start cutting.
Not on a Duster you don't. I have 275/60/15 drag radials on 15X8 rims with 4.5" backspacing and they fit perfectly with no rubbing.
Yeah, but a Duster is just a Nova rear with a Valiant front clip..
My DUSTER is not a NNOVEE i can`t say it it`s a MOPAR please tail me you are a MOPAR guy and you joking because that hurts but cubic inchs makes horse power ..THANKS
Well, considering I own a '75 Duster and have since 1988...yes, it was a joke!
[Re: Sport440]
#1035651
07/24/11 12:29 AM
07/24/11 12:29 AM
HYPER8oSoNic
Desert Tracker
Hyper, No my 248* cam is not a solid. Its the old MP .509 I am stepping up to the MP .590 though with the new combo. Also #3000 And not to be left behind or caught up in the old time warp. Im going to test a modern comparable Comp cam. It does look much better on paper Im coming out of time warp, maybe.
The statement of the "time warp" wasn't to "insult" anyone, using "old school" methods. If it did, MY apologies. Heck, I use that method sometimes and it STILL WORKS. My point, basically, was to not be biased in opinion of technology. To me, it doesn't matter the type of method used to build power. As long as you can get SOLID results of good performance from a combo, that's what counts. There is NO set approach. If you have a strong combination going on, perfect it, fine tune it. Just don't change it cause of TIME (AGE) or the fact others DON"T APPROVE. That's not being an individual, you're becoming a follower, for those TWO reasons alone! 1970's, were great times but I KNOW I can't go back!!
[Re: w7smallblock]
#1035652
07/24/11 01:04 AM
07/24/11 01:04 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Pity, I tell ya.
Sometimes, people mistake these threads as a bash a big, or bash a small block deal.
I didn't see it that way at all and the few points I mentioned, I consider critical and therefore should be optimzed no matter the cubic inch, to attain the lowest possible ET.......IMO.
[Re: HYPER8oSoNic]
#1035654
07/24/11 06:12 PM
07/24/11 06:12 PM
Posts: 5,618 long island NY
Ari440
long island NY
its all about MONEY
big block or small block
its money and time into it
1.39 9.85 - 137 mph
