Page 9 of 15 1 2 7 8 9 10 11 14 15
Re: big block VS small block [Re: BryanRad] #1035575
07/21/11 11:46 PM
07/21/11 11:46 PM
PA
W
w7smallblock Offline OP
W
PA
One thing that is almost always left out of these conversations is the torque curve. Another argument that comes down to do you want a slip to say my engine made xxx horsepower or do you want an et slip that shows how well the engine makes power over a broad range and is utilized.
I agree the big block torque curve will be broader, but I said with gear and converter to match the combo's. With that said a big block with a 275/60/15 tire with 3.23 shifted at 6000 rpm would fall back to 3500 in second, then back to 6000 and fall back to 4000 in drive. While a small block with the same tire and with 4.10 shifted at 7500 would fall back to 4500 in second and back to 7500 then fall to 5200 in drive. That small block would have 500rpm more pull in 1st-2nd shift and 300rpm more pull in 2nd-drive thats 800 rpm more total. This is figured on both cars with a 727 and stock gear ratio's. This would also be with the converter dead locked which we know don't happen, but still more useable rpm from the small block.
Re: big block VS small block [Re: w7smallblock] #1035576
07/22/11 12:02 AM
07/22/11 12:02 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
the rpms will drop more on big block but i think the torque would make up for the drop i think the torque of the big block would be the factor. at both being 500 horsepower the big block would have 200 ft.pounds of torque over small block
Re: big block VS small block [Re: d-150] #1035577
07/22/11 12:15 AM
07/22/11 12:15 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
no matter the argument no substitue for cubic inch. no matter what u do to the smallblock if you do the same mod to the big block the big block will make more power
Wrong!!!!
Put an same identical turbo on either engine and then tell me the same thing.....smaller cubes will almost always win out due to being able to run into a turbos higher PR because the big block is going to turbine choke sooner and not be able to get into the maximum flow of the compressor due to PR.
And don't even try and come back with a rebuttal unless you actually know what you are talking about....
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: big block VS small block [Re: instigator] #1035578
07/22/11 12:19 AM
07/22/11 12:19 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
ok put a turbo on a 360 that makes 500 horsepower and 440 that makes 500 horsepower same difference i will play your silly game
Re: big block VS small block [Re: d-150] #1035579
07/22/11 12:34 AM
07/22/11 12:34 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
I said the same turbo.....you stated that nothing done to either motor could allow the smallblock to make more power....
and it is not always about cubic inches...there is an equalizer....And I know what it is......
And my GAME is it!
65 Barracuda
Re: big block VS small block [Re: instigator] #1035580
07/22/11 12:39 AM
07/22/11 12:39 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Do you see anything strange that I see smallblock ruling the east coast head up classes...these guys spend more money than No_Politics on their cars so you know there is the best of everything in them either big or smallblock!
65 Barracuda
Re: big block VS small block [Re: instigator] #1035581
07/22/11 12:59 AM
07/22/11 12:59 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
original post was both 500 horsepower. optimal power the 440 would not use same turbo as 360.and who says a big block can not turn same rpms as a small block
Re: big block VS small block [Re: d-150] #1035582
07/22/11 01:30 AM
07/22/11 01:30 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
and if this is correct i could get a srt4 motor make it 500 horsepower put it in a 3200 lb race car and spank all the small blocks and big blocks
Re: big block VS small block [Re: d-150] #1035583
07/22/11 01:41 AM
07/22/11 01:41 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
But you stated Power not ET in your statement....I am just stating the facts that that old statement of you can not replace cubic inches is old school and antiquated.....
65 Barracuda
Re: big block VS small block [Re: S/ST 3040] #1035584
07/22/11 01:55 AM
07/22/11 01:55 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
such entertainment for free.
Re: big block VS small block [Re: d-150] #1035585
07/22/11 01:55 AM
07/22/11 01:55 AM
PA
W
W
PA
This post was about N/A motor. Power adder is a whole different ball game.
Re: big block VS small block [Re: ademon] #1035586
07/22/11 02:50 AM
07/22/11 02:50 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
231/237 cam in that 408 and 480ish HP ??? sounds more like maybe a 430hp engine
11.2:1 compression, single plane, etc. The 440 with smaller cam and less compression made 485. Heads were about equal but the small block actually has something called a combustion chamber and quench. I'm thinking it's a wash. I could be wrong, but the truck mph'd within about 3 mph between the 408 and the 440. So you tell me, is that 55 hp? 4800 lb truck.
Re: big block VS small block [Re: dodgeboy11] #1035587
07/22/11 09:37 AM
07/22/11 09:37 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
My understanding of this thread was, ETs for IDENTICAL HP numbers for two different size engines. NOT a "what can make more power with X modification".
Hopefully, all the engine builders who deal in max N/A engines are keeping tabs of this thread. All these years of trying to shift power UP was an excersize in futility. They should have been trying to increase TQ at 3000rpm.
Who knew that all they were doing was abusing the valve springs.
Perhaps this will signal the wave of the future......turbo diesels in Pro Stock, with 1000tq @ 1800rpm and 300hp @ 1801rpm.
Re: big block VS small block [Re: theclutcher] #1035588
07/22/11 10:22 AM
07/22/11 10:22 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Better than "Pass Time"!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: big block VS small block [Re: jim sciortino] #1035589
07/22/11 10:43 AM
07/22/11 10:43 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
The diesel analogy took the cake.
Re: big block VS small block [Re: emarine01] #1035590
07/22/11 10:52 AM
07/22/11 10:52 AM
Desert Tracker
Desert Tracker
They BOTH have to make 500 HP AND weigh 3000 lbs.
Looks like the original poster isn't going to settle
any argument and started one here.
I'm going to throw a cow chip in this thread and leave it alone, before !! How come
so many GOOD POINTS were produced in THIS thread, and not too many on the "383 vs. 440" thread? Hmm, basically the concept is the SAME, with the EXCEPTION of the vehicle weight.
Humm...... Cow Chip..... ..... How high do you turn your cow ....... .......
As high as it can go, without it letting loose all over you.
Ya ask a simple question and seems that cows just want to crap all over ya This post needs a little injection of bad humor every now & then
Bad humor on YOUR part. Why bring up cows crapping all over a person when it was a metaphoric statement about engines. At least, that how I put it as. The cow chip issue, I was trying to be funny, on that note alone.
Re: big block VS small block [Re: d-150] #1035591
07/22/11 12:35 PM
07/22/11 12:35 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
It is funny all this talk of 45yo ancient big and small block engines when these modern cars with tiny cid engines like the Boss 302 can kick ass to the tune of 11.70 stock with just drag radials
Re: big block VS small block [Re: ademon] #1035592
07/22/11 12:53 PM
07/22/11 12:53 PM
tennessee
mike54 Offline
mike54  Offline
tennessee
Re: big block VS small block [Re: mike54] #1035593
07/22/11 01:01 PM
07/22/11 01:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have the BADDEST big-block on my street............PERIOD.
Re: big block VS small block [Re: w7smallblock] #1035594
07/22/11 01:28 PM
07/22/11 01:28 PM
Desert Tracker
Desert Tracker
Lets say you build a 440 and a 360 both stock stroke to make the same horse power (500hp). Do you agree the 440 will make more torque given the larger stroke? Do you think with properly matched gear and converter for the engines in say a 3000lb car will run the same ET?
If they do run the same ET does this mean the smallblock would recover in between gear changes quicker to make up for being down on torque. I am trying to end an argument, so your thuoghts please.
First, never said anything against power adders.
Second, stock strokes, NO stroker combos
Yes, they would run close in times.
Yes, A smallblock would recover a bit quicker (depending on equipment). Again, depending on eeqipment and tune, top end hp rules, (shorter strokes) if torque peaks late in the midrange.
However, a high but nearly flat torque peak in the lower midrange, (longer strokes) can be equally as strong. There is another factor in trying to measure an engines performance potential. Rod/stroke ratio. Although NOT 100% accurate, but it gives an indicator of the engines basic potential for performance, (equipment being not part of equation). 340's, for example, have a 1.84 ratio - which lends them nicely to higher rpm power.
360's on the other hand, have a 1.71 - which gives them a GREAT advantage as a midrange high hp/high torque motor. SOLID base for a stroker or "standard arm" HOT street/strip.
440's have a 1.80 - which is nearly equal in performance as the 360, but with a slightly BETTER potential for higher rpm hp.
Not to say 360's can't rpm up but it also about the equipment (parts) which makes it all happen. Given both at the 500hp level, again, they would be nearly equal. A point about the 360's rev drop, it would NOT be the same as a 340's, unfortunately! It would be at slightly lower rpm than the 340's, characteristic to the 440's (again, equipment depending!). If the 440 has a balanced bobweight LESS than the 360's, it's a wrap!! But it's not needed for a 440 at the 500hp level. 500hp 440 engine builds are standard "street-level" combos, they are unnecessary, unless you WANT TO spent a bit more money on
the parts/balance job just to "maximize" that particular combo at THAT level!! At 550-600hp or MORE, IT IS absolutely beneficial!! It would be routine for the 360 (at 500hp) since the nature of smallblocks are to rpm quicker/higher than their big block counterparts. And you would want maximum hi-rpm reliablity from your smallblock!! Anytime you can REDUCE reciprocating weight, you are adding rpm and possibly more torque.
