Page 8 of 15 1 2 6 7 8 9 10 14 15
Re: big block VS small block [Re: Mr.Yuck] #1035555
07/21/11 06:09 PM
07/21/11 06:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Pretty hard to build a 440 with only 500 HP. We would have to go to the junk yard for a set of 906 heads.
But yet i have probably seen more high 11 second big block Mopar "race cars" at the track than anything else, then when you look under the hoods they look like they should run 9.50's.
The above wouldnt be so bad if it wasnt 100% true
Almost as bad as the proverbial huge inch 67-69 Camaro's you see all the time that only seem to run 10.50's and are all cut up to heck so they will even run that good
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: big block VS small block [Re: B3422W5] #1035556
07/21/11 06:14 PM
07/21/11 06:14 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Every brand of car has their share of cheese.
Every brand, big block and small block have their share that make
people say, "There's no #@&*% WAY that's all that's done to it!"
Re: big block VS small block [Re: earthmover] #1035557
07/21/11 06:18 PM
07/21/11 06:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
i got it
nah don't lock it. I don't think anybody here has taken anything personally. It's all good fun.
Re: big block VS small block [Re: Mr.Yuck] #1035558
07/21/11 06:37 PM
07/21/11 06:37 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
So using some of you guy's theory any engine 500 hp no matter what the torque "say one is 500 the other 700" they will run the same if every other aspect of the combination is optimized? not trying to argue just trying to understand.
Re: big block VS small block [Re: vttm] #1035559
07/21/11 07:00 PM
07/21/11 07:00 PM
PA
W
w7smallblock Offline OP
W
PA
Yes this is right torque is equallized through the rear gear. Say 3.91 for the big block and 4.88 for small block (as an example)
Re: big block VS small block [Re: w7smallblock] #1035560
07/21/11 07:03 PM
07/21/11 07:03 PM
PA
W
W
PA
No don't it. Some good info here and some funny logic also.
Re: big block VS small block [Re: Mr.Yuck] #1035561
07/21/11 07:09 PM
07/21/11 07:09 PM
organ
maximum entropy Offline
organ
sorry I'm out. Just trying to inject some logic into the conversation. By the way I'm not the only one who disagrees with you. I'll stand by what I said. A car that makes 500hp and over 570lbs of torque (and a 440 will) would beat a 500hp SB that makes maybe 500lbs of torque. geared and stalled correct blah blah blah
this here is incorrect.
Re: big block VS small block [Re: HYPER8oSoNic] #1035562
07/21/11 07:10 PM
07/21/11 07:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
They BOTH have to make 500 HP AND weigh 3000 lbs.
Looks like the original poster isn't going to settle
any argument and started one here.
I'm going to throw a cow chip in this thread and leave it alone, before !! How come
so many GOOD POINTS were produced in THIS thread, and not too many on the "383 vs. 440" thread? Hmm, basically the concept is the SAME, with the EXCEPTION of the vehicle weight.
Humm...... Cow Chip..... ..... How high do you turn your cow ....... .......
As high as it can go, without it letting loose all over you.
Ya ask a simple question and seems that cows just want to crap all over ya This post needs a little injection of bad humor every now & then
Re: big block VS small block [Re: w7smallblock] #1035563
07/21/11 08:10 PM
07/21/11 08:10 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
It's not a Mopar comparison but it is somewhat relevent to the arguement.
I think it was Hot Rod a few years back that built two engines, a small block 406 and a big block 406, same cam profile.
I cant remember the Dyno numbers but the big block heads flowed better so it kicked butt on the small block. They both went in the same Chevelle with the weight the only difference,
the smallblock managed 12.50's I think and the big block ran 12.30's or 12.20's, even with the weight disadvantage and the same cubes.
Re: big block VS small block [Re: moparmanjames] #1035564
07/21/11 08:19 PM
07/21/11 08:19 PM
S/ST 3040 Offline
S/ST 3040  Offline
The "big block" clearly made more power. You're right, not the same
as the scenareo posed here.
Re: big block VS small block [Re: S/ST 3040] #1035565
07/21/11 08:46 PM
07/21/11 08:46 PM
MD
HEMI472 Online content
HEMI472  Online Content
MD
i am glad i read this
now i am going to tear out my 488 inch v-10 and put in a stock 340 they both make around 300 hp so there will be no difference.
i am liking the small blocks
Re: big block VS small block [Re: HEMI472] #1035566
07/21/11 09:02 PM
07/21/11 09:02 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
Not a bad idea. Come to think of it I wasted the money on my cummins should have just got the 360 same hp, just a gear change from same performance.
Re: big block VS small block [Re: moparmanjames] #1035567
07/21/11 09:04 PM
07/21/11 09:04 PM
PA
W
W
PA
The only reason the big block won was because the gear and converter favored it. You cant use the same gear and converter becuase the big block made more torque.
472HEMI you might as well pull the v-10 and put in a 340 because when you don't get the truck out of the garage it doesn't really matter. They both will rust away to nothing at the same rate.
Re: big block VS small block [Re: HEMI472] #1035568
07/21/11 09:05 PM
07/21/11 09:05 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
just get the 358 ci nascar motor there going for about 6 g's..and they only make 850hp
Re: big block VS small block [Re: fishy340] #1035569
07/21/11 09:50 PM
07/21/11 09:50 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Not alot of straight forward answers to the op question, but alot of good info.
Id say take your best year stock 440 and your best year stock 360...poof ya got your answer, a great 440 and a very mild small block.
I love my small block strokers but have the need for a low budget BB stroker just to get the best of both worlds. Not to either brag or complain, but for what ive in one of my stroker six pack small blocks I could have a killer BB, really killer.
Id rather see posts not on how to beat each other, but how to beat that supercharged stang, or the blown chebbie down the street with a ????
Re: big block VS small block [Re: quick77rt ] #1035570
07/21/11 10:01 PM
07/21/11 10:01 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
One thing that is almost always left out of these conversations is the torque curve. Another argument that comes down to do you want a slip to say my engine made xxx horsepower or do you want an et slip that shows how well the engine makes power over a broad range and is utilized.
Re: big block VS small block [Re: quick77rt ] #1035571
07/21/11 10:05 PM
07/21/11 10:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Which one will last longer at the 500hp level? My vote goes to the BB.
Mopar to the bone!!!
Re: big block VS small block [Re: w7smallblock] #1035572
07/21/11 11:10 PM
07/21/11 11:10 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Your Whole argument is correct on paper.
But it isnt in reality. The 500 Hp SB power curve will be smaller then the BB.
Unless both combos are pegged at the start to finish at 500 HP, witch they wont be. The BB with the wider torque/hp curve will be the winner.
Your argument is a theoretical math/physics argument on paper , not a reality argument.
500 + 500 = 1000 on paper.
500 hp BB and 500 hp SB doesnt = the same ET with different torque curves!
Further, in reguards to HP, math and physics being so precise.
Why is it that every stinking website for mph vs weight = xxx amount of HP is so far off from one another by 100 HP or so.
HP is a Calculated number based off of RPM. Both Torque and HP are for real. Torque can be measured, but HP is calculated.
And it can be calculated pretty accurately, But not on a vehical that races down a track with a variable Torque Band width.
For the arguments sake Im on the side of the BB is the winner in this same 500HP senario. Because in reality, the two combos will never be fully optimized to the 500HP
Re: big block VS small block [Re: Sport440] #1035573
07/21/11 11:35 PM
07/21/11 11:35 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I was just wondering what made the fastest pass at the heads up shoot out they just had on here. Was it a small block or big block?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: big block VS small block [Re: Sport440] #1035574
07/21/11 11:42 PM
07/21/11 11:42 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
no matter the argument no substitue for cubic inch. no matter what u do to the smallblock if you do the same mod to the big block the big block will make more power
