Page 7 of 15 1 2 5 6 7 8 9 14 15
Re: big block VS small block [Re: Mr.Yuck] #1035535
07/21/11 12:54 PM
07/21/11 12:54 PM
PA
W
w7smallblock Offline OP
W
PA
I see your point but WHY would you go that route if you could do it with less stall and gear? Maybe the post should be which costs less to build... anyway both will work just a matter of how you want to get there.
Why would you go that route? Because not everybody wants a low rpm high tourqe big block and NO the post shouldn't be which one cost less to build... this post is about 500hp big and small blocks geared and convertered to take advantage of the engine package. Maybe I should have posted which one is more EFFICIENT that really gets you big block guys panties in a wad.
Re: big block VS small block [Re: jim sciortino] #1035536
07/21/11 01:30 PM
07/21/11 01:30 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
RPM my stroked 340 made all its power @ 5800 rpm!that was shown on a dyno 506hp @ 5800 rpm 540lbs of torque was low 4000 rpm
Re: big block VS small block [Re: w7smallblock] #1035537
07/21/11 01:39 PM
07/21/11 01:39 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"Maybe I should have posted which one is more EFFICIENT that really gets you big block guys panties in a wad."
nah just the Hemi guys.
Re: big block VS small block [Re: Mr.Yuck] #1035538
07/21/11 02:12 PM
07/21/11 02:12 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Pretty hard to build a 440 with only 500 HP. We would have to go to the junk yard for a set of 906 heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: big block VS small block [Re: pittsburghracer] #1035539
07/21/11 02:21 PM
07/21/11 02:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Re: big block VS small block [Re: dodgeboy11] #1035540
07/21/11 02:46 PM
07/21/11 02:46 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Which one weighs more..
A: 1 pound of Lead...
B: 1 pound of feathers...
Maybe that will help..
Has nothing to do with "Big or Small" blocks..
Chris...
Heres my comparison analogy
Witch one hits the ground first.., from a 1320' drop!
A: 1 pound of lead..
Mike
WELL, if the pound of feathers is in the shape of a parachute...
still wouldnt mather if it was in total vacum
Re: big block VS small block [Re: Mr.Yuck] #1035541
07/21/11 02:49 PM
07/21/11 02:49 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Pretty hard to build a big block 440 with only 500 HP. We would have to go to the junk yard for a set of 906 heads.
fixed?
Re: big block VS small block [Re: RemCharger] #1035542
07/21/11 02:55 PM
07/21/11 02:55 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
back on track, there is a reason people dont put some tank engine making max power at a tad over 2000rpms in dragcars atleast i dont know of anyone doing it with succes.
however 500hp moving a set weight is always 500hp
Re: big block VS small block [Re: HEMI472] #1035543
07/21/11 03:33 PM
07/21/11 03:33 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
ok since you guys want to fight about big and small block lets try this.
lets say you have a 360 with 500 hp and 200 foot pounds of torque and you put in a 4 inch crank and now it still has 500 hp but now it has 400 foot pounds of torque. you are saying it will run the same?? same 3000 pound car.
ok so where are all you small block guys now?? come on now it easy its yes or no???
Re: big block VS small block [Re: HEMI472] #1035544
07/21/11 03:46 PM
07/21/11 03:46 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
YES!
Fully optimized!
YES!
Less cubes will make the horsepower at higher rpm, thus requiring a lower rearend gear, which multiplies torque. And I'm not talking out my ego like half you guys here. I am small block converting big block guy. Mostly cuz the aftermarket has made it cheaper and easier.
So YES guys your 500 cubic inch engine making 550 horsepower doesn't run any quicker than a 550 horsepower smallblock. Is it more streetable with 3.55 gears and 3k stall? Yes. But its not gonna be any faster then the 550 hp 340 that's running 5.13s.
If you don't get it by now maybe go back to school and take a physics class.
Re: big block VS small block [Re: viperblue72] #1035545
07/21/11 03:54 PM
07/21/11 03:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
maybe a better post would be "practical" What's the easiest/cheapest block to make 500 hp? Any block big/small can make power if you toss enuff money into it.
Re: big block VS small block [Re: Mr.Yuck] #1035546
07/21/11 04:01 PM
07/21/11 04:01 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
nobody cares what it costs or how to get 500hp the question is what is the differece in torque going to do
Re: big block VS small block [Re: HEMI472] #1035547
07/21/11 04:07 PM
07/21/11 04:07 PM
V
viperblue72 Offline
viperblue72  Offline
V
Maybe you should stop puffing out your chest and try to understand what we are saying. The next time you are beat by a small blocl ask yourself how it could be possible since the engine doesn't make enough torque.
Re: big block VS small block [Re: viperblue72] #1035548
07/21/11 04:15 PM
07/21/11 04:15 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
At least you guys are giving the small block a chance by only comparing it to a 440...
Re: big block VS small block [Re: viperblue72] #1035549
07/21/11 04:23 PM
07/21/11 04:23 PM
PA
W
W
PA
YES!
Fully optimized!
YES!
This is correct thats why I made this post to stop an argument, but no matter what some people just don't get it and never will.
Mr. Yuck if you keep saying the post should be this or that quit posting on my post and start your own. I would like the post to stay on track (GOT IT)
Re: big block VS small block [Re: w7smallblock] #1035550
07/21/11 05:39 PM
07/21/11 05:39 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
YES!
Fully optimized!
YES!
sorry I'm out. Just trying to inject some logic into the conversation. By the way I'm not the only one who disagrees with you. I'll stand by what I said. A car that makes 500hp and over 570lbs of torque (and a 440 will) would beat a 500hp SB that makes maybe 500lbs of torque. geared and stalled correct blah blah blah
Re: big block VS small block [Re: Mr.Yuck] #1035551
07/21/11 05:44 PM
07/21/11 05:44 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
YES!
Fully optimized!
YES!
forgeting about torque multiplication? those 70lbs of diference wont be to the bigblocks advantage anymore if you measure at the wheels,under the cirkumstance that the smallblock will make its power at a higher rpm and therefore having a lower geared rearend and more converter stall.
Re: big block VS small block [Re: 1Fast340] #1035552
07/21/11 05:58 PM
07/21/11 05:58 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: big block VS small block [Re: S/ST 3040] #1035553
07/21/11 06:08 PM
07/21/11 06:08 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i got it
Re: big block VS small block [Re: S/ST 3040] #1035554
07/21/11 06:08 PM
07/21/11 06:08 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
This is Gettin' GOOD!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
