Page 3 of 15 1 2 3 4 5 14 15
Re: big block VS small block [Re: fishy340] #1035455
07/19/11 05:59 PM
07/19/11 05:59 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
360 block,i'd go with 340 better and stronger..but any way i've posted this a few times,,4" crank,40 over bore,eddie heads not even touched,750 hp carb,4.30 gear 29" tire w a 3500 stall treemaster conv..motor made 504hp at 5800rpm and 546lb'S OF torque 418ci went 10.80's in a 3200 dart sport..cam was flat tapped bullit made it 255/255 @ 50 588 lift
Your math is out a bit. 418 does not = 360.
Re: big block VS small block [Re: Mr.Yuck] #1035456
07/19/11 06:01 PM
07/19/11 06:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You guys are debateing about nothing that this thread has to do with just
The fact is 500 hp IS 500 hp weather it is a BB or SB if the car is tuned to hook perfect and keep the engine in it's own power band one will not be faster than the other. The SB will make less TQ but will end up with a lower gear ratio and TQ at the wheel will be the same.
As for you guys and your peeing match, 500 hp is easy with either combo and costs about the same with either. A 1/2 decent port job on a X head or a 906 and similar priced cam intake headers carb... will make 500 hp. Machine work is the same and every component is going to be almost the same $$$. The SB will naturally turn more RPM to make the same HP but so what, matched with a 904 instead of a 727 the SB combo is going to be nearly 200lbs lighter. A 4 cylinder civic can make NA 500 hp and no TQ, they will just run super low gear ratios and turn the 500 hp into the same TQ as a 440 at the tires and the bottom line(the bottom of the tire) is what matters, it can still run as fast in a 3000# car but it just needs more gear to get the same TQ at the tire... of course a 500 hp honda is VERY much more expensive.
Re: big block VS small block [Re: RemCharger] #1035457
07/19/11 06:09 PM
07/19/11 06:09 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
He said that he would go with a 340....340,.040 = 418"!!!!!
Re: big block VS small block [Re: MIKES_DUSTER] #1035458
07/19/11 06:19 PM
07/19/11 06:19 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
whats a 40 over 340?.. 345?
Mike you forgot the 4" crank that was never installed at the factory. 4" crank = not stock anymore.
Re: big block VS small block [Re: w7smallblock] #1035459
07/19/11 07:04 PM
07/19/11 07:04 PM
gregsdart Offline
gregsdart  Offline
Question one-yes
Question two- yes
question three - maybe?
For number three, it is all about the most efficient way to get the most average hp to the track the full length of it.
Odds are the small block will have a narrower power band than the BB, and will have more flash and stall. So, it kinda doesn't matter. You build the converter and pick the gear ratios to make the power band you have work.
When you say both making 500 hp, I assume you also mean they will average the same hp over a wide enough range so that they will be competitive.
Re: big block VS small block [Re: gregsdart] #1035460
07/19/11 07:07 PM
07/19/11 07:07 PM
Oh yeah...340,.040 and a 4" crank = 418" Is that better???
Re: big block VS small block [Re: MIKES_DUSTER] #1035461
07/19/11 07:35 PM
07/19/11 07:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
.... ..... ....You guys are funny
Re: big block VS small block [Re: gregsdart] #1035462
07/19/11 07:42 PM
07/19/11 07:42 PM
MD
HEMI472 Online content
HEMI472  Online Content
MD
Question one-yes
Question two- yes
so we now have 2 pages and 2 answers. so you all are say put steep gears in the small block to make up the difference in torque.but if you put all that gear in it to make up torque is it going to make it to the finish line in its power range?? to much gear and its going to slow down
Re: big block VS small block [Re: HEMI472] #1035463
07/19/11 08:26 PM
07/19/11 08:26 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
4.080 bore + 4" crank = 418 sorry i should have expained what 40 over meant a little better
Re: big block VS small block [Re: w7smallblock] #1035464
07/19/11 08:55 PM
07/19/11 08:55 PM
organ
maximum entropy Offline
organ
500 hp is 500 hp. if both cars are optimized, the small block car will go faster (less weight). the two engines will have different torque curves, because it will take a bigger and/or better head and cam for the 360 to make that number, not because of shorter stroke. torque is a factor of cubic inches more than anything else. the 360 won't need to make (and won't make) as much torque to make 500 hp, because it will be higher up in the rpm range. the cars being optimized will level the playing field. that's where the weight advantage will win the game for the small block, imo.
Re: big block VS small block [Re: maximum entropy] #1035465
07/19/11 09:09 PM
07/19/11 09:09 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i told you the was coming everybody should have left when i did
Re: big block VS small block [Re: maximum entropy] #1035466
07/19/11 09:15 PM
07/19/11 09:15 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
they weigh the same
Re: big block VS small block [Re: maximum entropy] #1035467
07/19/11 09:18 PM
07/19/11 09:18 PM
MD
MD
they weight the same?????
Re: big block VS small block [Re: sixpackgut] #1035468
07/19/11 09:19 PM
07/19/11 09:19 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
they weigh the same
I was going to say that, but was wondering if he ment reciprocating weight
Re: big block VS small block [Re: RemCharger] #1035469
07/19/11 09:29 PM
07/19/11 09:29 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Big block Mopar was designed in the mid 50's, small block LA was designed in late 60's so I guess there is more technology in a small block. If they are gonna make the same horse power then there would be more pride in a small block. I have race big and small block Mopar, but I use to make more money with a small block on the street races. I donīt street race anymore but I'm kind of hook on small blocks and believe me to make 500 horsepower it's less expensive to go small block.
Re: big block VS small block [Re: Mopar-Al] #1035470
07/19/11 09:31 PM
07/19/11 09:31 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think that fat guys need big blocks and thin guys need small blocks, and when you put a fat guy in a small block you need a fatter wallet.... and that's all there is too it
Re: big block VS small block [Re: maximum entropy] #1035471
07/19/11 09:39 PM
07/19/11 09:39 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
hp=torquexrpm/5252
Let's try to shed some light on this subject instead. A dynamometer only measures torque, which is only the ability to do work. Gearing is a way to gain mechanical advantage, so even a 1/4 horse motor can make 500ft lbs with low enough gearing. The rest is a math equation which is the amount of work in a time period(horsepower). So higher rpm torque peak= more horsepower. If I was wrong then those nascar engines would run like turds.
I don't really agree with the recovery thing. Say a 440 is shifting into second cause its done by 6k rpm. The 360 is still gonna be in 1st up to 7k rpm and only drops down to 5.5k on the shift, which the horsepower is all gonna come in the same due to the extra rpm. An optimum drag car only uses what 2k rpm of its powerband?
Can a 440 with 500 hp spin just as high? yes! But its torque drops off much faster at that level, therefore doing more harm then good.
Also Ive had a 500hp smallblock, a few of them. And I know I was definitely going just as quick as the big blocks at that level.
Re: big block VS small block [Re: emarine01] #1035472
07/19/11 09:45 PM
07/19/11 09:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: big block VS small block [Re: viperblue72] #1035473
07/19/11 09:45 PM
07/19/11 09:45 PM
I will just say big block.
Re: big block VS small block [Re: ] #1035474
07/19/11 09:54 PM
07/19/11 09:54 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
If you take the best factory 440 (sixpack) you should be able to get 500 with a cam and intake , rockers, headers.Throw in some cylinder head work too.. for laughs.
I can't see that happening with a 360. And if I'm right, there goes the budget deal. (which wasn't really in the original question)
