Page 2 of 15 1 2 3 4 14 15
Re: big block VS small block [Re: dragram440] #1035435
07/19/11 02:03 PM
07/19/11 02:03 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
well lookin at Andy f's book and seeing for myself for 30yrs it takes alot to get 750hp from either,,o yea my friends w9 nitrious motor at 11.1 comp make um 780 something hp on pumpgas NO METH INJECTION...PS i know big dogs make big hp with bb's but it takes exotic heads an after market block..or A 400 block cause 440's stink..etc etc..i just dont like when a guy with a 13 sec bb thinks he's god...i think he's stuck in the 70s with his logic
Re: big block VS small block [Re: dragram440] #1035436
07/19/11 02:05 PM
07/19/11 02:05 PM
IL
furious70 Offline
furious70  Offline
IL
good grief, a 439" SDSS bullet is hardly what the OP is talking about
If the 440 and 360 both make 500hp the 360 is going to do it at a higher rpm. That higher peak tq might require a deeper gear than the 440, might not. But the increased rpm range of the 360 is also going to allow it to stay in lower trans gears longer if the same rear gears are used, making better use of the available torque multiplication.
This concept in reverse is why many people find that stockish 440's don't really run any quicker with 4.10's than they did with 3.23's.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: big block VS small block [Re: HEMI472] #1035437
07/19/11 02:05 PM
07/19/11 02:05 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
you have no clue what ur talkin about,a good set of j or x heads,a machine shop that knows what its doin and 4" cast crank stroker kit..and u are the one with meth injection on ur BB BEAST? MY little sb pump gas will beat ur meth injected slug by 1/2 the track..THATS WHAT I KNOW ABOUT SB'S...all u say is alot more work!!! but u cant elaborate..u need more work to a stock 440 block cause there boat anchors weight wise
what does any of your posts have to do with what the guy asked??? this is about the 3rd or 4th post where you get on a post to pound on your own chest bragging up your small block. how fast and cheep it is SO WHAT you have a fast small block wohoo
u can have a lane next to me also hemi472..lol
Re: big block VS small block [Re: fishy340] #1035438
07/19/11 02:15 PM
07/19/11 02:15 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
you dont want that because my big block does out run your small block.and for you to know everting your engine builder races a big block
Re: big block VS small block [Re: fishy340] #1035439
07/19/11 02:22 PM
07/19/11 02:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah stroker crank, machine work and what size cam? SB are fine but cost more to build per HP. I had a great running 340. Ported J heads, 1.6 roller rockers small 455 cam TTi headers, RPM intake 750 holley thing ran great, however same components in a 440 would have generated much much more power and probably been a second faster. I run meth so I can run pump gas. All it does is make the 93 "act" like 114. You call a 440 block a boat anchors...what's the 360? You don't need diddly to make a 9:1 440 run low 12's in a B-body or low 11's in an A-body. You can do it with stock iron heads and a smaller hydro cam. I can't imagine what you'd need to run low 12's in a b-body w/ a 340. I'm starting w/ a one hundred cubic head start.
What have you done to your SB? How much $$$ do you have in it? did you put it togther in your garage? what stall..gear? what that car weigh? what are you shifting at? Do you drive it to and from the track? apples to oranges. Should I go buy an a-body, step up my converter and gear toss on a single dominator and meet you?
Re: big block VS small block [Re: HEMI472] #1035440
07/19/11 02:25 PM
07/19/11 02:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
his small block is anything but cheap or small...he has 7 less cubic inches than I do and his car probaly weghs 1000lbs less. His car is super nice and runs like a MoFo, as I've stated anything can be made fast.
Fact is you're not going to make 500HP w/ a small block as easy or as cheap as a 440.
Re: big block VS small block [Re: Mr.Yuck] #1035441
07/19/11 03:55 PM
07/19/11 03:55 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
right this is why racing cars are grouped according to engine cid, weight. could you imagine the 1970 trams am cars with big heavy 440's 460's 454's in them trying to brake and turn, or in drag racing a 4,000 lbs charger with a stock 440 racing a stock 428scj 68 mustang, bottom line the 440 should win if the hp is the same, due to more torque but then again if both were in a 3,400 lbs duster i would think the lighter 360 with the lighter and less hp eating 904 would make for a close race, oh and i forgot the hi torque of the 440 might kill the 8 3/4 so it might need a heavy dana where the 360 will not kill the 8 3/4.
Re: big block VS small block [Re: w7smallblock] #1035442
07/19/11 04:13 PM
07/19/11 04:13 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Both engines set up with optimum gearing they would run the same. Even in a heavy car the steeper gearing offsets the engines torque. Both engines will be slower in a B body. I have to admit though the 360 is gonna be more sensitive to slightly wrong tuning. For example my neighbor built a high horsepower 302 with afr 185 heads and a decent roller cam. Then he put street gears and converter in it and he can only muster a 13.40 quarter mile. With some 4.88s and higher stall he'd be mid 11s.
And yes 500 horsepower is gonna be easier with a big block. This pissing match you guys are having is retarded. Years ago the sb had the w2 and edelbrock heads not to mention the 4" crank for 300 bucks. Back then it would have been a good argument but since then edelbrock and 440 source have changed the fact that 440s were once expensive.
Re: big block VS small block [Re: HEMI472] #1035443
07/19/11 04:52 PM
07/19/11 04:52 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
It's funny how really no body is answering his question. 440 vs 360 both having there stock stroke crankshaft. Both having the same hp. Both running the same weight 3000 lbs. He said match your gears and tq converter. 500 hp is just that 500 hp. the bigger stroke will get you out a little easier, hp is what pulls the same on top end. The converter should stay in your power band. So actually, it boils down to the chassis/drivetrain tuneup to see who is first at the finsh I would say. Drag coeficient could play a roll in it also. Maybe i'm wrong, but I do know it isnt about a body or 4 inch cranks or any of the other stuff he is asking for
Re: big block VS small block [Re: Mopar-Al] #1035444
07/19/11 05:01 PM
07/19/11 05:01 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
360 block,i'd go with 340 better and stronger..but any way i've posted this a few times,,4" crank,40 over bore,eddie heads not even touched,750 hp carb,4.30 gear 29" tire w a 3500 stall treemaster conv..motor made 504hp at 5800rpm and 546lb'S OF torque 418ci went 10.80's in a 3200 dart sport..cam was flat tapped bullit made it 255/255 @ 50 588 lift
Re: big block VS small block [Re: Mopar-Al] #1035445
07/19/11 05:01 PM
07/19/11 05:01 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Imo if everything was built ideally for either motor and weight being the same, a big block would out run a small block all day. Simply because it has more torque.
Also to add, if I had a w9 motor with a roller that was 13.1 and only made 650, Id burn that turd to the ground
Re: big block VS small block [Re: redruM] #1035446
07/19/11 05:04 PM
07/19/11 05:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
lol
Re: big block VS small block [Re: redruM] #1035447
07/19/11 05:23 PM
07/19/11 05:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm glad you arent around my turd
Re: big block VS small block [Re: MR_P_BODY] #1035448
07/19/11 05:35 PM
07/19/11 05:35 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Re: big block VS small block [Re: redruM] #1035449
07/19/11 05:36 PM
07/19/11 05:36 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
They werent W9 heads but W2's.
Re: big block VS small block [Re: 69B3GT] #1035450
07/19/11 05:37 PM
07/19/11 05:37 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Ive seen 7600 out of a stock stroke 360 with mildy ported iron heads and a .484MP cam. Bash away.
I dont think my 440 will go that high (okay okay, I know it wont)
haha, Ive had stock big blocks higher Chris! BUT, your not making any power revving it that high...
Re: big block VS small block [Re: redruM] #1035451
07/19/11 05:42 PM
07/19/11 05:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd be willing to run you heads up with my turd
Re: big block VS small block [Re: BB70DUSTER] #1035452
07/19/11 05:46 PM
07/19/11 05:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's just it no need to spin a BB that high.
Re: big block VS small block [Re: Mr.Yuck] #1035453
07/19/11 05:52 PM
07/19/11 05:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your wrong... any engine can be made to run 10K rpm
and make power....maybe your talking stock.... I
was building a 514CI BB that would make power at 9K+
Re: big block VS small block [Re: redruM] #1035454
07/19/11 05:53 PM
07/19/11 05:53 PM
V
viperblue72 Offline
viperblue72  Offline
V
I disagree! Say the big block has 3.91 gears ideally because its gonna peak at 5600.
The 360 is gonna need say 4.88s ideally because it will peak about 6500. The 440 is gonna have a 3800 stall vs the 360s 4800. I think the torque will be equalized at the rear tires. And at this point what role does the rotating mass inside the engine play. Not to mention 100 less pounds of engine.
