Champion Radiators anygood? #1034984
07/18/11 02:00 PM
07/18/11 02:00 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Who's running a Champion Radiator, What do you think of it?
Re: Champion Radiators anygood? [Re: midnite360] #1034985
07/18/11 02:07 PM
07/18/11 02:07 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
yep... good...
Re: Champion Radiators anygood? [Re: 52savoy] #1034986
07/18/11 03:39 PM
07/18/11 03:39 PM
Goodyear Arizona
Goodyear Arizona
lol thanks
Re: Champion Radiators anygood? [Re: midnite360] #1034987
07/18/11 03:53 PM
07/18/11 03:53 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I am keeping my eye on this thread. Was thinking about this one with 3 cores. http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWAX%3AIT
or this one with 4 cores. http://cgi.ebay.com/ebaymotors/70-71-72-...sQ5fAccessories
Re: Champion Radiators anygood? [Re: GomangoCuda] #1034988
07/18/11 04:23 PM
07/18/11 04:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you are running a A-body with 70 and up aluminum water pump you can't use the stock fan shroud. And the upper water neck is close to the centerline of a mechanical fan. So you will need a fan 2" smaller diameter than the MP fan package if you want a mechanical fan. And you'll need to make your own shroud.
Re: Champion Radiators anygood? [Re: midnite360] #1034989
07/18/11 04:40 PM
07/18/11 04:40 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I bought a three core 26" one from on Ebay earlier this year. I had to send the first one back because it was pretty twisted; about two inches diagonally. The second one was twisted as well but only slightly so I used it. I had to redrill all mounting holes, as well as the shroud mounting holes. Other than that, it works fine. Cools well on my '70 Challenger with warmed 360 and A/C.
Re: Champion Radiators anygood? [Re: Mapandjlp] #1034990
07/18/11 05:16 PM
07/18/11 05:16 PM
Goodyear Arizona
Goodyear Arizona
Was going to go with a BE COOL but the translines run to the side of them and I don't know what I would use to get my lines to go up there.
Re: Champion Radiators anygood? [Re: midnite360] #1034991
07/18/11 05:42 PM
07/18/11 05:42 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Theres one in my moms barracuda. Had to redill the mounting holes and we dont run a shroud on there. Car stays cool with a mild 360
Re: Champion Radiators anygood? [Re: GomangoCuda] #1034992
07/18/11 06:19 PM
07/18/11 06:19 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I have a 2-row 26" one in my 74 318 Valiant. It cools just fine even in traffic when it was 90+ degrees out. I bought it from a seller on here. The install was fairly straight forward. The trans cooling lines had to be bent by hand a little bit, I had to drill mounting holes in the aluminum of the rad, and would have had to modify it slightly for a shroud. Overall it was very easy to install and worth it and it cools better than the old one even without a shroud.
Re: Champion Radiators anygood? [Re: 69B3GT] #1034993
07/18/11 06:23 PM
07/18/11 06:23 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
we bought ours for angies challenger 3 core with dual 10 fans
havent got the motor fired up yet but it fit very nice
all holes lined up perfict even the shroud holes lined up
i need to buy a 4 core for my cuda but havent bit the bullit yet
only thing i can complain about is there was no male pigtail to go with the female wireing on the fans but other then that very happy with it
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Champion Radiators anygood? [Re: GomangoCuda] #1034994
07/18/11 07:09 PM
07/18/11 07:09 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I have the three row 26" model of that one. I had to make a seal from closed cell foam to seal the top and bottom of the shroud to the radiator.It had about 1/2" to 3/4"gap,but fit flush on the sides. Other than that it works great. I run a 7 blade factory clutch fan and a factory shroud.Overall it was a pretty good deal for the money,lots cheaper than some of the other options out there.
Re: Champion Radiators anygood? [Re: 67_Satellite] #1034995
07/18/11 07:59 PM
07/18/11 07:59 PM
Goodyear Arizona
Goodyear Arizona
Thanks for the Opinion guys keep em coming, It's going in a 73 dodge dart some I am hoping there wont be that much modification needed.
Re: Champion Radiators anygood? [Re: midnite360] #1034996
07/18/11 10:54 PM
07/18/11 10:54 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
have a 4 row in my Challenger, seems to do the job...
Re: Champion Radiators anygood? [Re: 70Challengerse] #1034997
07/19/11 06:38 PM
07/19/11 06:38 PM
Northeast Texas
W
wingedwarrior Offline
W
Northeast Texas
I put a 3 row in my 1970 Satellite back in May. I went on the complete HotRod Powertour without any problems...running the A/C!! I would highly recommend Craig to purchase one from. It did need a little modification but was worth it in the cost savings compared to the BeCool.
Re: Champion Radiators anygood? [Re: wingedwarrior] #1034998
07/19/11 08:11 PM
07/19/11 08:11 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
No problems here. Keeps my stroked magnum cool.
Re: Champion Radiators anygood? [Re: StrkrDart69] #1034999
07/19/11 08:54 PM
07/19/11 08:54 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Have one in my 68 Charger and it keeps my 408 magnum stroker cool with A/C. Not sure how it would do with a big block though.
Re: Champion Radiators anygood? [Re: rapom] #1035000
07/20/11 08:42 PM
07/20/11 08:42 PM
Goodyear Arizona
Goodyear Arizona
Just ordered one, Thanks for the reviews.
Re: Champion Radiators anygood? [Re: midnite360] #1035001
07/20/11 09:44 PM
07/20/11 09:44 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Bought three over the years..best bang for the buck
Re: Champion Radiators anygood? [Re: autoxcuda] #1035002
07/21/11 10:59 PM
07/21/11 10:59 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Can't run an 18" flex fan with one?
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Champion Radiators anygood? [Re: MY340] #1035003
07/21/11 11:05 PM
07/21/11 11:05 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Do they have the dual-pass option ?
