Gas tank pad, foam rubber or felt tar paper? #1034758
07/18/11 12:46 AM
07/18/11 12:46 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hey, any thoughts on which one to use? (e-body)
Thanks.
Re: Gas tank pad, foam rubber or felt tar paper? [Re: cudabitten] #1034759
07/18/11 09:35 AM
07/18/11 09:35 AM
okla.
O
okie Offline
okie  Offline
O
okla.
Use the tar paper won't hold moisture like the foam. Ronnie
Re: Gas tank pad, foam rubber or felt tar paper? [Re: okie] #1034760
07/18/11 02:26 PM
07/18/11 02:26 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The repo foam ones are a joke. Go with the tar paper
Re: Gas tank pad, foam rubber or felt tar paper? [Re: Morty426] #1034761
07/18/11 02:32 PM
07/18/11 02:32 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Who is making the correct stuff?
Has anyone seen the Restoration Specialties tank pads?
Re: Gas tank pad, foam rubber or felt tar paper? [Re: 71TA] #1034762
07/18/11 07:50 PM
07/18/11 07:50 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
I thought Dixie Restoration had the correct gas tank pads...
Re: Gas tank pad, foam rubber or felt tar paper? [Re: rayztoy] #1034763
07/18/11 08:51 PM
07/18/11 08:51 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I am also looking for one
Mega parts has them for $15
Don't know what it is made of.
Re: Gas tank pad, foam rubber or felt tar paper? [Re: gygeneral] #1034764
07/19/11 08:37 PM
07/19/11 08:37 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
quantra(sp)fuel tanks
Re: Gas tank pad, foam rubber or felt tar paper? [Re: meepmeep70] #1034765
07/19/11 09:59 PM
07/19/11 09:59 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
It doesn't appear to be tar paper.
Original on left and tar paper on right.
Re: Gas tank pad, foam rubber or felt tar paper? [Re: Snoopy] #1034766
07/20/11 08:06 AM
07/20/11 08:06 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Re: Gas tank pad, foam rubber or felt tar paper? [Re: rayztoy] #1034767
07/20/11 01:18 PM
07/20/11 01:18 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I have a few samples of that paper. After 2 years of looking I found it IS a pulp/paper based product. Unbleached kraft pulp is what I've found. Many of these materials used to be parrafin saturated. That material has the extra waffle pattern on it.
There is a similar material on the outside of 62-65 B body A/C and non A/C heater boxes. In the attached picture you can even see the tar paper like stripe that is used to line up the sheets (like for shingles). I'm guessing it was an old tar paper like material that was used before the modern Tyvek (sp?) house wraps.
The Quanta tank pads are the foam ones. Nothing like OEM.
Re: Gas tank pad, foam rubber or felt tar paper? [Re: 71TA] #1034768
07/20/11 01:40 PM
07/20/11 01:40 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My original 69 pad was definitely tar paper. Send me your origial pattern, and I'll cut you a new one from the other 95 ft of a roll I have left over.
