Re: Best way to clean rusty fuse holders?
[Re: Carsavior]
#1034614
07/18/11 12:13 AM
07/18/11 12:13 AM
RapidRobert
I was just wondering the same thing (if I had a glass beader that'd work). I might try the vinegar/salt & see if it works on ferrous
[Re: Steve340]
#1034618
07/18/11 03:13 PM
07/18/11 03:13 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
I just did this on my ramcharger...I used a mini-wire wheel on a dremel tool...worked like a CHAMP
also used dialetric grease when I popped the new fuses in
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: Paul_Fancsali]
#1034621
07/19/11 12:04 PM
07/19/11 12:04 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have a small wire brush made of brass wire. I use it to clean my torch tips, but it will make quick work of your conectors. Don't need to remove the fuse box for soaking this way If it's already out either soak it or use a small media blaster. The dremel idea will also do a great job.
I have mechanical Aptitude. I can screw up anything.
