Clearancing wilwood calipers for streetlites #1034481
07/17/11 09:14 PM
07/17/11 09:14 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
So I finally got my rear disc swap and going into it, I knew I was going to have to grind on my brand new calipers because of my 6.5 backspace. Ive taken off quite a bit of material so far and its still not clearing, its making me nervous that I'm going to ruin my calipers. I just wanted to see if anyone else has done this and how far they got into the calipers. I'm sure it will be fine but just wanted to double check.
Re: Clearancing wilwood calipers for streetlites [Re: redruM] #1034482
07/17/11 09:24 PM
07/17/11 09:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My Wilwoods cleared fine on my 8 3/4 with 8" BS
Centerlines
Re: Clearancing wilwood calipers for streetlites [Re: MR_P_BODY] #1034483
07/17/11 09:29 PM
07/17/11 09:29 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
I bet they do, billet specialties did a wonderful job designing these wheels
Re: Clearancing wilwood calipers for streetlites [Re: redruM] #1034484
07/17/11 09:40 PM
07/17/11 09:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you grinding on the outer radius to clear... can
you add a wheel spacer
Re: Clearancing wilwood calipers for streetlites [Re: MR_P_BODY] #1034485
07/17/11 09:49 PM
07/17/11 09:49 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
Yes, the flat spots on either side of the pads. Can't run a wheel spacer, the tire is already right at the 1/4. If I had to guess, I didn't measure it because it didn't seem that tight, looked like I could knock a little off and be good to go..... Which is not the case unfortunately. I'm almost to the point of letting them clearance themselves
Re: Clearancing wilwood calipers for streetlites [Re: redruM] #1034486
07/17/11 11:07 PM
07/17/11 11:07 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
i had same issue u have to change your brake setup to a areo space setup which is smaller
Re: Clearancing wilwood calipers for streetlites [Re: cesar perez] #1034487
07/17/11 11:41 PM
07/17/11 11:41 PM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
Well that sucks, guess I'll be buying those new wheels I've been wanting sooner than I thought
Re: Clearancing wilwood calipers for streetlites [Re: redruM] #1034488
07/17/11 11:52 PM
07/17/11 11:52 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
what is the bolt pattern what car are u tring to install them on
Re: Clearancing wilwood calipers for streetlites [Re: cesar perez] #1034489
07/18/11 12:44 AM
07/18/11 12:44 AM
Columbus, OH
redruM Offline OP
redruM  Offline OP
Columbus, OH
Duster, 5x4.5, 15x10, 6.5bs. I've been wanting go to a 12" rear and run a 17x4 up front for awhile, guess I found a reason now
Re: Clearancing wilwood calipers for streetlites [Re: redruM] #1034490
07/18/11 01:12 AM
07/18/11 01:12 AM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
if price is write could be interesed
