904 suddenly holds 2nd gear...like forever?
#1034428
07/17/11 08:21 PM
07/17/11 08:21 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Wifes car was in body shop like 4 months, now seems reluctant to automatically or manually hit "drive" 50 MPH sometimes, and with 3.91s that's kind of a drag. Sticky shuttle valve thing? All set to service with plus 4 even tho fluid looks great, cannot remember when I serviced last. Thoughts???? thanks, C
Re: 904 suddenly holds 2nd gear...like forever?
[Re: Sixgun]
#1034430
07/17/11 09:55 PM
07/17/11 09:55 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Make sure the spring is on the kick-down linkage.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 904 suddenly holds 2nd gear...like forever?HELP!
[Re: Sixgun]
#1034432
07/18/11 12:33 AM
07/18/11 12:33 AM
Sixgun
Western Washington
OK, valve body out...everything looks OK, whoever did the trans mods years ago took out the accumulator piston spring.No block rod. Piston moves freely...should I install a blocker rod? Some other posts on other mopar sites said it's not good to just let the piston flop back and forth.Doubt if that's my problem, but will it hurt anything to add the block rod? Guess I gotta gut up and clean the valve body and check for debris...this trans has worked great for a lotta years, don't understand why all of a sudden...
[Re: fox]
#1034439
07/18/11 04:49 PM
07/18/11 04:49 PM
Sixgun
Western Washington
OK, I can probably look up location of governor port, dunno if I have a gauge that goes that high, will look. Got the VB out and apart, small kine sludge, but the "shuttle valve" behind the spring loaded TV was sticky at first, sprayed out with penetrant and is free as can be now.There was in one passage some thick goo, maybe a gram or so, but maybe that was a dead end passage?Consistency of peanut butter and gray/black. Got an accumulator spring out of a parts loadflite, and will install in my 904 as per JohnRR's kind advice. I still am at a loss to explain why it came on so sudden, all I can think is it didn't like sitting for 4 months and some sludgy stuff set up either in the VB or the governor assy. Will try to air test clutch pack before I install VB.
[Re: Sixgun]
#1034440
07/18/11 06:51 PM
07/18/11 06:51 PM
Posts: 1,089 st.cloud fl
d-150
Smarter than a 5th grader?
st.cloud fl
[Re: d-150]
#1034441
07/18/11 06:57 PM
07/18/11 06:57 PM
Sixgun
Western Washington
Went to air check the clutch packs as per the service manual, 30 psi @ the 2nd and 3rd round port, I hear no "thunk". tried 40psi, still no "thunk". Went to youtube and saw the instructor dude covering unpressured hole while pressurizing the other.Will try this.
[Re: Sixgun]
#1034442
07/18/11 07:52 PM
07/18/11 07:52 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You're listening for the "thunk" and also for the sound of escaping air. Try kicking the air pressure up to 90 psi, I never understood why they want you to air check at pressures lower than normal line presure.
[Re: John_Kunkel]
#1034443
07/18/11 08:38 PM
07/18/11 08:38 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I agree , I always check wit hthe pressure that is coming from the compressor. The valvebody in my truck goes as high as 150psi WOT .
[Re: Sixgun]
#1034445
07/19/11 03:57 AM
07/19/11 03:57 AM
Sixgun
Western Washington
3)Jim Beam No 3rd gear, actually seems worse. Just an observation, now with the accumulator spring installed, reverse seems to be acting up and or not kicking in, but could be coincidence, or a worsening symptom of the real problem. Used to come in solid before todays band aids. First gear still solid but no jarring engagement like before, just firm. Time to decide what route to take.With the Wife going for her RN, I am in charge of all things expensive, so taking into account the 318 has over a quarter inch of crank endplay,I was already planning a swap of some sort... got lots of BB stuff ;-Thanks guys for the ideas and support!!!!Long live MOPARTS!!!!
