turbo heat #1034317
07/17/11 04:55 PM
07/17/11 04:55 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
You guys with twin turbos what do you do to keep all that heat
Under control? I hear about people getting 400-600 degrees under the
Hood on a hot day!!
Causing all sorts of problems.
Would a water cooled turbo help?
Re: turbo heat [Re: Big B] #1034318
07/17/11 08:19 PM
07/17/11 08:19 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
It might but there are no options for that unless your using an OE turbo.
Turbo blankets, coatings and wraps are your friends. Some sort of louvering or a cowl scoop will do wonders at letting alot of the heat out.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: turbo heat [Re: topfueldart] #1034319
07/18/11 09:27 AM
07/18/11 09:27 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
i wrapped my headers, ceramic coated the hot side of my turbo as well as got a turbo blanket for it. With my chevy hood it doesnt seem to get to bad under their
Re: turbo heat [Re: joshking440] #1034320
07/18/11 01:17 PM
07/18/11 01:17 PM
IL
furious70 Offline
furious70  Offline
IL
Mine isn't quite ready to run yet, but I bought blankets and plan to wrap at least the manifold to turbine inlet piping.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: turbo heat [Re: furious70] #1034321
07/18/11 02:00 PM
07/18/11 02:00 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
I'm in the planning stages of a twin turbo big block with Indy-1 heads for my 69 Sport Satellite. Just trying to think of everything before I start buying things. My biggest problem is going to be running all the plumbing. It seems from reading different forums that heat is a big issue when street driving. I might have to buy a cowl induction hood just so the heat can escape.
Re: turbo heat [Re: Big B] #1034322
07/18/11 05:06 PM
07/18/11 05:06 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I use a turbine blanket, header wrap on the manifold and downpipe along with shields where needed.... along with a cowl scoop to let the heat out.
Re: turbo heat [Re: Duner] #1034323
07/20/11 11:54 AM
07/20/11 11:54 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I drive mine. Seems to keep the heat out Okay.
