Re: Burnout Style/Technique Question [Re: oldiron] #1034280
07/18/11 05:15 PM
07/18/11 05:15 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Tim Hyatt, can reface the clutch discs for you. Do NOT throw them out.
Re: Burnout Style/Technique Question [Re: JERICOGTX] #1034281
07/18/11 05:29 PM
07/18/11 05:29 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
Thanks Jeff. Yep, Tim did reface the clutch disks (have 2 spares), its the flywheel and pressure plate facings that are toast. I like to look at them every now & then. This year I went back to an all steel flywheel and pressure ring.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Burnout Style/Technique Question [Re: oldiron] #1034282
07/18/11 08:15 PM
07/18/11 08:15 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
OK. Are you running the Vert still, or didn't you build a new car???
Re: Burnout Style/Technique Question [Re: JERICOGTX] #1034283
07/18/11 08:22 PM
07/18/11 08:22 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
Yep, back to running the vert. Last year I was running a 68 barracuda w/same drive train, but then I took it to a body guy in January who said it would be finished by march. I guess that I thought he meant 2011
Re: Burnout Style/Technique Question [Re: S/ST 3040] #1034284
07/18/11 08:52 PM
07/18/11 08:52 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Mike, you're going pitch a rod in the water box.
.... I try to keep it under 8000 RPM.
I already have.
Next year a 298" W7 head motor and 5 speed go in.
Life begins at 10,000 RPM !!!
Re: Burnout Style/Technique Question [Re: mloboda] #1034285
07/18/11 08:58 PM
07/18/11 08:58 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
So have I.
Re: Burnout Style/Technique Question [Re: oldiron] #1034286
07/18/11 09:36 PM
07/18/11 09:36 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Well if a body guy tells you it will be done in a certain month, you need to ask what year. LOL. Post pics of the Barracuda when it gets out of body shop jail.
Re: Burnout Style/Technique Question [Re: mloboda] #1034287
07/18/11 09:39 PM
07/18/11 09:39 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Your only going to run 5/8 of a engine? Life must begin when valve springs die.
Re: Burnout Style/Technique Question [Re: S/ST 3040] #1034288
07/19/11 11:04 AM
07/19/11 11:04 AM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
So have I.
I switched to Carrillo's when I rebuilt it.
