Best way to clean and re-paint K-member ?
#103421
08/11/08 10:13 PM
08/11/08 10:13 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, I have my K-member out, and want to make it look good. I would have it hot-tanked but, since I can't paint inside, I don't want to remove any paint that might already be there (or are they even painted there?). I'm leaning toward degreasing it with a bio-degradable cleaner, then blasting only the outside, followed by painting with (possibly) a satin-finish, black Rustoleum. Opinions? How about the paint choice? Would gloss be better? I'm not going for a 100 pt. restoration, but just want it to look good and not collect dirt too easily. Thanks for all replies!!
Re: Best way to clean and re-paint K-member ?
[Re: Fab64]
#103432
08/12/08 09:36 AM
08/12/08 09:36 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Hi all,
Your plan is pretty much what I did. Only difference is I used a wire wheel instead of blasting and also had the seams welded up a little better for strength. Painted mine satin black. Just shoot the paint around as best you can and don't sweat it too much.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Fab64]
#103433
08/12/08 05:59 PM
08/12/08 05:59 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Gotta go pick up parts at powder coat today or tomorrow including the K-member. easiest way IMO.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: 4BBodies]
#103437
08/12/08 06:14 PM
08/12/08 06:14 PM
DaytonaTurbo
Manitoba, Canada
POR 15 only peels off it the surface wasn't prepared correctly. The stuff is tough as Hell.
No, you're wrong. I followed their instructions to the letter including using all of their prep products. Still peeled. That stuff works okay for an interior surface like maybe the insides of your floors or something, but definitely not anything that's exposed to the elements.
[Re: 4BBodies]
#103439
08/12/08 06:46 PM
08/12/08 06:46 PM
RapidRobert
EPA regs eliminated hot tanks at the machine shops here so they went to oven baking. From how clean blocks/heads are when they come out of there I would go that route if it is available. that way every nook/cranny is squeaky clean then on to the proper primer/paint product which I am uninformed about also.
[Re: Fab64]
#103440
08/13/08 08:01 AM
08/13/08 08:01 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Mine was caked in 30 yrs of crap. I took a putty knife to it. Then I took EZ Off oven cleaner to it at the local car wash, then I sandblasted it, epoxy primed it and just shot it in Semi-gloss black. ALL front suspension parts were done this way.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
