Bell Housing Bolt Confusion 340/4spd question #1034183
07/17/11 02:06 PM
07/17/11 02:06 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
I need a little clarification. My car was missing some bolts when I got it and I'm trying to make sure I'm doing the correct thing. I checked my chassis manual and couldn't find the answer. I have the 5 bellhousing bolts installed that go through the bell housing to the engine. In some reference photos I have, it shows 2 bolts going in the lower ear of the engine. Looking at the bell housing bolt kit that R/T Specialties offers. It has the 5 like bolts and only 1 longer bolt for the ear area. Not 2. I should have 2 lower motor "ear" bolts. Correct?
65 Barracuda
70 Challenger
Re: Bell Housing Bolt Confusion 340/4spd question [Re: jrwoodjoe] #1034184
07/17/11 05:12 PM
07/17/11 05:12 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My 69 Barracuda 340 M4 has 7 bell housing-engine bolts, 7 split washers, and 1 wiring clip (J clip) for the backup light wiring.
5 hex bolts, 3/8-16 x 1 3/8, 9/16 AF, head mark "M".
2 hex bolts, 7/16-14 x 1 1/2, 5/8 AF, head mark "M".
5 split washers x 3/8 & 2 split washers x 7/16.
1 J clip, 5/16 capacity, 5/8 W x 1 3/8 L, .39 hole for 3/8 bolt. With PlastiDip.
All the above had engine paint overspray.
Re: Bell Housing Bolt Confusion 340/4spd question [Re: jrwoodjoe] #1034185
07/17/11 10:31 PM
07/17/11 10:31 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Hello Joe Yes mine also has the two lower bolts facing the opposite direction...
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Bell Housing Bolt Confusion 340/4spd question [Re: 19cuda73] #1034186
07/18/11 10:13 AM
07/18/11 10:13 AM
Tenn.
Tenn.
Thanks guys. Mine was missing one of the bottom bolts but I knew I had seen the bottom bolts on other engines. When I pulled up the bolt kit and it only showed one it had me second guessing. Not sure why it includes just one when you need two.
That gets me going again. Thanks guys.
