2006 Ram - Check Engine Light ??? #1033585
07/16/11 12:43 PM
07/16/11 12:43 PM
NC
DCM71cuda Offline OP
NC
2006 Ram - 185,000 miles - 5.7 Hemi
Check Engine Light came on today while driving down the road. No other differences in operation, gauges normal, etc.
I did the on-off keystroke. The odometer showed only dashes for about 5 seconds, and then said '- done -'
Any ideas?
Re: 2006 Ram - Check Engine Light ??? [Re: DCM71cuda] #1033586
07/16/11 02:23 PM
07/16/11 02:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have the codes read at any big parts store.Its free.Remember its just a guide to the problem though.Rocky
Chrysler Firepower
Re: 2006 Ram - Check Engine Light ??? [Re: DCM71cuda] #1033587
07/16/11 06:47 PM
07/16/11 06:47 PM
places
79powerwagon Offline
places
Tighten your gas cap?
Re: 2006 Ram - Check Engine Light ??? [Re: DCM71cuda] #1033588
07/16/11 11:27 PM
07/16/11 11:27 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
In these trucks, its actually called the Malfunction Indicator Lamp, or MIL.
Check the owners manual to see if you have maintained the truck according to the service recomendations. The 5.7 HEMI, especially with MDS, needs frequent oil changes and 5w20 oil. The components of the MDS system relys on clean oil since there are tiny orifices that will become blocked if dirty oil leaves deposits behind. My 2007 strictly states a 3000 mile oil change interval and I do my best to stick to it. Have you changed the Oxygen sensors? At 185 K, they are certainly ready for replacement. The spark plugs are NOT 100K plugs!!! These engines used standard plugs and need to be changed at every 30 K. Read the manual if you have heard different from Ford guys. Your best chances reside with maintaining the truck to factory specs. This engine is much more sophisticated than any 318, and it requires maintenence.
Re: 2006 Ram - Check Engine Light ??? [Re: Kern Dog] #1033589
07/17/11 03:55 PM
07/17/11 03:55 PM
NC
NC
So why doesn't it give me a code on the odometer?
As far as maintenance, I've changed plugs once/yr ever since I bought it (averaging about 30K miles/year). Current set has about 15K on them. I routinely change oil between 3-4K, using 5-20 synthetic and I use the 'large' size Baldwin filters. I have not changed the O2 sensors, so I may do that anyway.
Haven't had a change to get the OBD read, but I'll do that and see what it says.
Re: 2006 Ram - Check Engine Light ??? [Re: DCM71cuda] #1033590
07/17/11 08:16 PM
07/17/11 08:16 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Because only certain year Rams did
My 2004 Did Not also
Autozone / Advance Auto will read it for free like mentioned - You can also clear the code once done with the scanner
You can also pull the Pcm fuse under the hood to clear the code also - I dont remember the exact # on the fuse block
Write the code down and google search - Or go on any of the Dodge Truck forums
Or
Report back with a code and see what we can come up with
Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 2006 Ram - Check Engine Light ??? [Re: bee1971] #1033591
07/17/11 09:43 PM
07/17/11 09:43 PM
NC
NC
Or
Scott
Thanks...I thought pretty much all Chrysler stuff would read the codes through the on-off key sequence.
I don't want to clear it without finding out what it is. Hopefully will get by somewhere tomorrow to get it read.
Re: 2006 Ram - Check Engine Light ??? [Re: DCM71cuda] #1033592
07/18/11 04:00 PM
07/18/11 04:00 PM
NC
NC
P0128 coolant temperature.
Temp gauge reads in "normal" range, and coolant level is fine.
Suggestions? I'm thinking temp sensor or t'stat?
Re: 2006 Ram - Check Engine Light ??? [Re: DCM71cuda] #1033593
07/18/11 05:05 PM
07/18/11 05:05 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
This may help. Sounds like a stat issue. Taking too long to reach operating temp
http://www.obd-codes.com/p0128
Re: 2006 Ram - Check Engine Light ??? [Re: Dcuda69] #1033594
07/18/11 09:01 PM
07/18/11 09:01 PM
NC
NC
Any idea what fuse to pull to reset the light? My thought is to reset and see if it comes back before I start changing parts.
