Early B gas tank #103349
08/11/08 06:17 PM
08/11/08 06:17 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I am looking to replace the original gas tank in my '65 Coronet. Where is the best place to buy one? What brand? I have found Quanta and another brand made in Canada. I can't remember the name.
Also, is there a seal between the filler neck and tank? Replacements available?
Thanks for any info.
nd65
Re: Early B gas tank [Re: nd65] #103350
08/11/08 06:57 PM
08/11/08 06:57 PM
I got mine on ebay. The guy said they were made in Canada. It came with a neck grommet has been in for months no problems.There is a pad that goes between the trunk floor and the tank I got that from Quanta.
Re: Early B gas tank #103351
08/11/08 07:46 PM
08/11/08 07:46 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I forgot about a pad. Thanks.
Summit has a Quanta for $219 and Rock auto has a Spectra for $155. They are both the same part number CR12B. Both have same warranty.
Anyone else?
Re: Early B gas tank [Re: nd65] #103352
08/11/08 08:59 PM
08/11/08 08:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i got one from Herb's. around $200, fit and finish was good. the Paddocks going to have 10% off on their parts on their cruise in day, august 23rd.
Re: Early B gas tank [Re: lewtot184] #103353
08/11/08 09:40 PM
08/11/08 09:40 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
We got the spectra one at Carlisle last year and fit/finish is good. I believe it came with the grommet. It has been in for about a year with no problems. Just be sure the pickup is positioned near the bottom of the tank. Our's was elevated and would probably suck air when the fuel got low, so it took a little tweaking. You can look in the filler hole when the sender is installed.
Re: Early B gas tank [Re: Kevins493] #103354
08/11/08 11:53 PM
08/11/08 11:53 PM
Long Valley NJ
65Belv DDB Offline
mopar addict
65Belv DDB  Offline
mopar addict
Long Valley NJ
The tanks are made by Spectra in Canada and Quanta is a distributor. Same tank, same part number.
'65 Plymouth Belvedere
'05 Dodge Ram Daytona
Re: Early B gas tank [Re: 65Belv DDB] #103355
08/12/08 10:09 AM
08/12/08 10:09 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I thought they might be the same tanks.
lewtot, I hope to be at the Paddock cruise in. I'll check the price. You going to it? I hope to bring the wife's Dart as well. She just got it a week ago.
Thanks,
Re: Early B gas tank [Re: nd65] #103356
08/12/08 11:47 AM
08/12/08 11:47 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i need to turn some refinance papers into the bank to get a second mortgage approved so i'll have enough $$$ to buy a tank of gas. other than that and the weather is good i hope to get one my old heaps out there, .
