68 Roadrunner trim code #1033487
07/16/11 06:50 AM
07/16/11 06:50 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
HI Can ayone tell me what trim D4S would be in a 68 RR ?
Re: 68 Roadrunner trim code [Re: Teamx] #1033488
07/16/11 10:25 AM
07/16/11 10:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
D is deluxe trim level , 4 is vinyl split bench seat, S is the color... silver and black .
Re: 68 Roadrunner trim code [Re: JohnRR] #1033489
07/18/11 07:09 AM
07/18/11 07:09 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Thanks!
Re: 68 Roadrunner trim code [Re: JohnRR] #1033490
07/18/11 09:45 AM
07/18/11 09:45 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
It looks like this...
Re: 68 Roadrunner trim code [Re: 68jim] #1033491
07/18/11 09:46 AM
07/18/11 09:46 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
And this...
Re: 68 Roadrunner trim code [Re: 68jim] #1033492
07/18/11 12:46 PM
07/18/11 12:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Jim, what's the SPD & assy plant on your car? My early (9/30/67) St.Louis RR has same interior but the seat inserts are unpleated Reed grain. Same with another early L.A. RR I used to own.
Your inserts are the '69 style pleated & different grain.
Unpleated Reed inserts were to the best of my knowledge correct for '68, but maybe there was a change at some point; I suspect it may have been because the unpleated inserts stetched too much. I knew a few cars back then with that interior and I recall some stretching out.
Re: 68 Roadrunner trim code [Re: topside] #1033493
07/18/11 01:31 PM
07/18/11 01:31 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Mine is a fairly late (5-4-68) build RR from the Lynch Road plant. The headliner and carpet are the only replacements. Everything else in the interior is still original. The car was raced for a couple of years then parked. Mice got into the headliner and the carpet had a hole when they added a floor shifter vice the column. The silver headliner was difficult to find.
Re: 68 Roadrunner trim code [Re: 68jim] #1033494
07/18/11 01:44 PM
07/18/11 01:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thanks for the info; the insert material has been a "thing" with me; what you're saying supports the theory that the '69-style inserts were phased in sometime during '68.
Re: 68 Roadrunner trim code [Re: topside] #1033495
07/18/11 02:49 PM
07/18/11 02:49 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Cool info - I never knew about the different seat inserts before! Of all the date codes I found on my car, the seats were the latest dates. The rear seat sections have some small metal tags with the dates of May 10 and May 13, 1968. Basically within a week of the May 4 SPD. Never found any tags on the front bench lower section. Owner's manual shows the car was delivered the first week in June 68.
Re: 68 Roadrunner trim code [Re: 68jim] #1033496
07/18/11 04:42 PM
07/18/11 04:42 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here is a local 2 owner '68 Road Runner coupe w/D4S interior, original seats.
St. Louis, MO assebled coupe w/109 SPD (1/9/68)
Re: 68 Roadrunner trim code [Re: 6bblgt] #1033497
07/18/11 11:46 PM
07/18/11 11:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd like to hear from more guys with this interior - known original '68s only - as far as assy plants & SPDs.
Back in the '80s, only the later pleated-insert style covers were available; the dies for the Reed pattern didn't exist any more, and had to be made using the covers from my car as samples. I got a free set of new covers out of the deal. So this has always been something of interest to me.
