Removing Under Coating #1033177
07/15/11 09:13 PM
07/15/11 09:13 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
What is the best way to remove a thin layer of undercoating in the trunk area where it's getting repainted???
Re: Removing Under Coating [Re: 72 RR DUDE] #1033178
07/16/11 01:12 AM
07/16/11 01:12 AM
Joliet, IL Area
tranch Offline
tranch  Offline
Joliet, IL Area
I just got done removing a heavy undercoat off the inner fenders of my 64 300. I used a hand torch and heated/softened the udercoating then scraped it off with a dull chisel/stiff scraper. Cleaned the rest off using a pre-paint prep/cleaner, hit the whole inner fender with a red scuff pad then primed it.
Re: Removing Under Coating [Re: 72 RR DUDE] #1033179
07/16/11 01:23 AM
07/16/11 01:23 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Small torch and scraper. Not as bad a job as you think once you get the "rythem".
Re: Removing Under Coating [Re: superwrench] #1033180
07/16/11 02:29 AM
07/16/11 02:29 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
a heat gun works too. not a hair dryer. wear a glove on your scraping hand.
Re: Removing Under Coating [Re: Golden-Arm] #1033181
07/16/11 09:56 AM
07/16/11 09:56 AM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
I agree on the propane torch and scraper , it's not as bad as expected .
Harbor Freight has a cheap torch with the tip about 2 1/2 - 3" wide. It worked better then a regular propane torch when I did my Cuda with factory undercoating .
remove carpet, wiring, etc on the other side also
wear gloves...... The stuff will fall off in sheets
Donnie
Re: Removing Under Coating [Re: DonnieLawson] #1033182
07/17/11 03:16 PM
07/17/11 03:16 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Follow-up w/wiping down w/lacquer thinner or equiv.
Re: Removing Under Coating [Re: 2fast4yourBrain] #1033183
07/17/11 10:25 PM
07/17/11 10:25 PM
NE Ohio
mopar383 Offline
mopar383  Offline
NE Ohio
Did the torch and scrapper on my Challenger. Lots of time but not too bad
81 Dodge Ram My dad bought brand new... my 17 year old sons project
Jeep Wrangler Unlimited .....my wife's baby
Durango....my DD
Caravan...an awesome parts hauler
72 Dart
