Re: HOW FAST WITH W2's
[Re: rt66jim]
#1032993
07/15/11 03:25 PM
07/15/11 03:25 PM
[Re: fishy340]
#1032994
07/15/11 03:35 PM
07/15/11 03:35 PM
Posts: 186 South Carolina
KRYPTONITE
South Carolina
I have a 72 dodge dart, going with 4:30 gear 295/55 Drag radials, 727 tranny gonna have My converter guy build me a custom converter, gonna go with Caltracs, I have already did the relocation kit, and gonna Mini it, also plan on putting a CM cage in it, I had Ben over at PROMAX build me a short block, 408 eagle forged crank, H beam rods,Dimond forged pistons,
Looking at a set of W2 econo heads/ SIXPACKGUT on the board is gonna port them
Im looking to run 6.30 6.20 on motor on pump gas
Am I asking to much from the car/combo???
[Re: KRYPTONITE]
#1032995
07/15/11 03:45 PM
07/15/11 03:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you get the car light enough it wouldnt be a problem
[Re: KRYPTONITE]
#1032997
07/15/11 05:04 PM
07/15/11 05:04 PM
MR_P_BODY
I dont plan on cutting the car up alot,
What stroke do you plan on running... without some fairly large cubes you might be asking a bit much
[Re: KRYPTONITE]
#1033000
07/15/11 07:16 PM
07/15/11 07:16 PM
MR_P_BODY
To run a 6.20 thats a 9.75 pass on the 1/4 so its gonna take some power to get there in about a 3200# car, about 650 hp
[Re: Plymouth340]
#1033002
07/15/11 10:37 PM
07/15/11 10:37 PM
Posts: 850 Georgetown, TX
sc4579
Georgetown, TX
Went 10.80's in a 3200 lb Dart Sport with a 360, aluminum rods, light weight pistons, 4.88 gears.
2023 Challenger Scat Pack 1320 2016 Jeep Renegade
[Re: KRYPTONITE]
#1033003
07/16/11 01:14 AM
07/16/11 01:14 AM
Posts: 12,402 Taxes & Virus's R-US, NY
Dragula
6.80's not too much trouble, 6.20's, well that's a taller order, so more than 13:1, probably aluminum rods, tunnel ram, girdle on the bottom end etc...
[Re: Al_Alguire]
#1033005
07/16/11 05:12 PM
07/16/11 05:12 PM
Posts: 1,745 Maryland
340_Dart
Maryland
How fast have you guys gone on pump gas??? Remember he said pump gas... Sure a 13:1 4" crank motor can run low 10s or high 9s, but not a pump gas motor in a 70s dart... I've gone 11.24@119.50 best on 89 pump gas in my 3350lb race weight dart' with a 9.75:1 416 and econo W2's
[Re: 340_Dart]
#1033007
07/16/11 06:22 PM
07/16/11 06:22 PM
Dragula
How fast have you guys gone on pump gas??? Remember he said pump gas... Sure a 13:1 4" crank motor can run low 10s or high 9s, but not a pump gas motor in a 70s dart... I've gone [Email]11.24@119.50[/Email] best on 89 pump gas in my 3350lb race weight dart' with a 9.75:1 416 and econo W2's
Mine went 10.80's with 13:1 and a 904...I am switching to 11:1 and a 727 on pump gas, so we will see....Shooting for low 11's
