3 inch vs 2.5 inch exhaust question #1032871
07/15/11 01:53 AM
07/15/11 01:53 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
My 69 road runner has been sporting a TTI complete long tube header system with 3 inch pipes connecting H-pipe into DynoMax mufflers and out the back for about 5 years.
Since i lowered the car the exhaust system rubbs pretty much all the time and it was just plain aluminized pipe so it's looking pretty bad now.
I was thinking of going to a 2.5 stainless system with their X-pipe and was wondering if anything will change for the better or worse with smaller diameter pipes??
The engine is the original 383 still in there.
Any thoughts on what i might see differnt in performance if i go for the smaller pipes?
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032872
07/15/11 02:18 AM
07/15/11 02:18 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
you prob won't notice much change,except it will be quieter.
A stock engine may even run better as it will keep the exhaust hotter and move better.
I wouldn't go to a 3" unless you plan to hot rod the engine.
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032873
07/15/11 02:26 AM
07/15/11 02:26 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Unless you are over the 500hp level, I bet you won't see a loss in performance. I asked a similar question years ago before I chose for my Duster.
Ride eternal, shiny and chrome
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032874
07/15/11 02:31 AM
07/15/11 02:31 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Might even run better - a stock 383 should only need 2 1/2 duals with a crossover. The 3" might have actually been too large to scavenge properly.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032875
07/15/11 02:46 AM
07/15/11 02:46 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The new system will be a nice package w/ a sotck or near stock engine. I had a low-po 383 that did very well w/ HP manifolds, 2.5 pipes, X pipe, and Magnaflows. Exhaust was 2.5 all the way to the bumper.
I want my fair share
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032876
07/15/11 09:37 AM
07/15/11 09:37 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
raise the car back up!
scavaging is done in the first 12" of the header from the header flange at the head.
2 1/2 will be fine but that's a nice system on there now!
Re: 3 inch vs 2.5 inch exhaust question [Re: Dodgem] #1032877
07/15/11 10:19 AM
07/15/11 10:19 AM
No way man, low and slow is the way to go!
Ok so it's likes i may just go back to the 2.5 and try to find the stainless sttel pipes as myu car sits outside all the time and it's getting to look pretty rusty now.
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032878
07/15/11 10:24 AM
07/15/11 10:24 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Put a 440 in it and then the headers won't hang as low.
Re: 3 inch vs 2.5 inch exhaust question [Re: DirectSubjection] #1032879
07/15/11 12:56 PM
07/15/11 12:56 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Nowhere near enough flow requirement in a stockish 383 to need 3" exhaust; 2 1/2" mandrel bent is overkill.....but nice.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 3 inch vs 2.5 inch exhaust question [Re: DPelletier] #1032880
07/15/11 01:04 PM
07/15/11 01:04 PM
GomangoCuda Offline
GomangoCuda  Offline
It might in fact be quicker with 2 1/2".
Re: 3 inch vs 2.5 inch exhaust question [Re: DPelletier] #1032881
07/15/11 01:05 PM
07/15/11 01:05 PM
dogdays Offline
dogdays  Offline
agreed.
R.
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032882
07/15/11 01:16 PM
07/15/11 01:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
2 1/4"....2 1/2" max on that 383 combo with a H pipe
Re: 3 inch vs 2.5 inch exhaust question [Re: DAYCLONA] #1032883
07/15/11 06:55 PM
07/15/11 06:55 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Stu, if you decide you want to sell the 3", please drop me a PM. I have a 493 b-body project that could use it. Thanks! Lee.
Re: 3 inch vs 2.5 inch exhaust question [Re: Lee446] #1032884
07/15/11 07:39 PM
07/15/11 07:39 PM
Ok Lee and yes i am going to sell it. The local muffler shop is going to make me a deal on the new exhaust system for parts only and free labor. All i have to do it put a little sign up saying they did the job and let people look under the car as advertizing.
Now i am thinking of going to a side outlet exhaust using these SpinTech mufflers.
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032885
07/15/11 08:31 PM
07/15/11 08:31 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
The luxuries of being a MOPAR celebrity,now go find a hemi builder and get comped a new motor.
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032886
07/15/11 08:35 PM
07/15/11 08:35 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
On a Road Runner I think the rear exit exhaust would look a whole lot better. Side exit exhaust is more appropriate for the pony cars (cuda, challenger, mustang camaro).
If you want to keep your exhaust pipes from rusting on the outside you can remove them, lightly spray the pipes with silver header paint. Once the paint dries roll the pipe system under the car on a creeper so it doesn't get scratched up, and then lift it into place and bolt it up.
I did this to my old mustang with a can of vht. The paint will stink pretty good for the first few miles while the heat cures it.
Re: 3 inch vs 2.5 inch exhaust question [Re: Neil] #1032887
07/15/11 09:10 PM
07/15/11 09:10 PM
I have always had rear exiting exhaust and just want to change up the look for awhile. The way i park in right up to my new custom garage door and when i start it it echos off the door as well as making watery condinsation marks. The side outlest should be cool and the car is so modifed anyway it's no biggie to me.
Re: 3 inch vs 2.5 inch exhaust question [Re: MidPenMopar] #1032888
07/15/11 10:20 PM
07/15/11 10:20 PM
Central NC
gch Offline
gch  Offline
Central NC
It will be LOUD.
