340 Block Sleeving Question #1032851
07/15/11 01:34 AM
07/15/11 01:34 AM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Is it possible to re-sleeve all 8 holes on a 340 LA-based block to a larger starting bore size. Say 4.10 to 4.25"? This would not be a race application, more like a lightweight/high torque street bruiser.
I'm not a machinist, nor do I fully understand the cooling properties of the LA engines, so sorry if this question is a little out there.
Thanks!
Mo' Farts
Moderated by "tbagger".
Re: 340 Block Sleeving Question [Re: Grizzly] #1032852
07/15/11 03:00 AM
07/15/11 03:00 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Good ??, i don't have the answer, but i would bet its not a good idea due to the 340 thin walls to begin with
Re: 340 Block Sleeving Question [Re: ademon] #1032853
07/15/11 06:19 AM
07/15/11 06:19 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Yes. Then the simplest and cheapest is to use a 318 block, as it will do the job just as well as another LA. The sleeved block could be weak in the deck between the cylinders, but with iron heads on it builds a solid structure, at least if you are not racing it. The sleeves will be wet, and could leak water, so you better use Bars Leak or similar to avoid problems.
An alterantive would be to concrete fill almost to top and bore out to your wanted size. Should be cheaper. Use a good cooler for motoroil, and increase the ring gap. Fun project!
Re: 340 Block Sleeving Question [Re: Grizzly] #1032854
07/15/11 01:35 PM
07/15/11 01:35 PM
If you do decide to do that make sure and use ONLY Ductile Iron sleeves
Re: 340 Block Sleeving Question [Re: Cab_Burge] #1032855
07/15/11 02:22 PM
07/15/11 02:22 PM
dogdays Offline
dogdays  Offline
The real deal is this: After you have spent close to $800 on sleeving the block, the bottom end will still be the weak point. Get to the 600 hp mark and the block fails. The answer to both your questions is to use a race block.
R.
Re: 340 Block Sleeving Question [Re: dogdays] #1032856
07/15/11 03:18 PM
07/15/11 03:18 PM
sweden
sshemi Offline
sshemi  Offline
sweden
spend the money on the heads instead and you will have more performance
Re: 340 Block Sleeving Question [Re: sshemi] #1032857
07/15/11 04:43 PM
07/15/11 04:43 PM
Guitar Jones Offline
I see this magical 600 HP figure bandied about all the time yet no one has any pics of the carnage or proof that that is why the engine met it's demise. My new stroker should be in the 650-670 range with a stock block. If it splits in half I'll post pics.
Speed-O-Motive makes a 460 or 470 something small block using Darton .200 sleeves. You'll have to look it up as I can't get there from the work confuser.
OK up to a 471 CID, link added.
http://www.speedomotive.com/ps-615-74-speed-o-motive-uber-block-assembled-custom-short-block.aspx
Re: 340 Block Sleeving Question [Re: Guitar Jones] #1032858
07/15/11 07:23 PM
07/15/11 07:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i agree with dogdays. start with a good foundation. get a r3 race block. start out good, finish good. stay safe, seeya.
Re: 340 Block Sleeving Question [Re: Grizzly] #1032859
07/15/11 08:50 PM
07/15/11 08:50 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i had a stock block 340 with 620ish HP,,,cracked cylinder wall twice..now R3 block 7 years no problems,,,spend the money now not later...I'm just sayin
Re: 340 Block Sleeving Question [Re: Plymouth340] #1032860
07/15/11 10:35 PM
07/15/11 10:35 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
A guy here in town does this all the time to make a light weight race block. Uses flanged sleeves and interlocks them together. Supposedly makes a good combo. I have personally never done it.
PM me I can give you a name and phone number
Leon
Re: 340 Block Sleeving Question [Re: Leon441] #1032861
07/16/11 02:31 AM
07/16/11 02:31 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Guitar Jones: That link you provided was awesome. Really impressed with how complete the whole engine package is.
I also agree with you on the HP ceiling being a non-issue.
Leon: thanks for the offer, would'nt mind seeing a photo of what this guy is doing.....
Mo' Farts
Re: 340 Block Sleeving Question [Re: Grizzly] #1032862
07/18/11 02:38 PM
07/18/11 02:38 PM
orange city,FL
Demon340GSS Offline
Demon340GSS  Offline
orange city,FL
Hi grizzly,
The answer to your question is a definate "Yes !!!"
I am building a 457 cu in out of a 72' 340 motor.
It has been sleeved by Divorak ( think he is still in business in Waldo, Florida)
I will include a few pictures to show where i am at.
It is an Old project for me that I have still not finished as I have been running a big block 540 stroker and 8-71 BDS in a pro street/drag race dodge demon 340.
the 340 is out of this same car, but is not numbers matching to the car.
We figure it out like this...
4.200 bore size x 4.125 stroke crank or as the formula goes...
4.200 X 4.200 X 4.125 X 8 X .7854 = 457.19
I was told that I could go even bigger, but wanted to try this combo out first.
It has probe pistons that stick up .033 out of the hole.
W2 heads with 2.08 intakes and 5 angle valve job (30,35,45,60,70 )
Mopar Performance valves that are back cut/front cut w/ .372 stem.
Solid roller cam 622/624 and also split duration 258/264*
Heads where done by Dynamic racing engines in Tampa, Job # 253 & #254 ( not sure if he is still in business either?)
We have a holley strip dominator w2 intake with a adapter plate and a single 1050 dominator at this time.
Combustion chambers are 66 cc with the w2 heads and a fel pro .045 compostion head gasket.
Valve to piston clearence is .115 intake and only .028 exhaust ( so we need to flycut the exhaust side of the piston's a bit!)
Piston to head clearance is .135
rockers and cam are crane roller.
I have since bought a cat gear drive for it and need to do the machine work to install it ( drill and tap a hole in front of block)
Our block has been filled up to the freeze plugs with hard blok (had to make it/mix runny just to fill it and wait a long time for it to dry!!!)
Pistons have the ring lands moved down a bit for use with nitrous fogger set up.(just in case)
If we figure it right our pistons leave us at 12.2 to 1 compression ratio.
They are available in any combo such as a lower 9.to 1 ratio if we wanted to change ( we like to race!)
I would not be discouraged in the least bit to do it again with a block that had a cracked bore as was our case.
Not sure what kind of power it will make yet.
I dont dissagree with starting with the R3 block if you have the means, We did it with this one just to find out what we could build to be different.
Hope the pictures come thru!
Grant Eaton
386-561-1181.
Owner of Original collector and restored original mopars from Mr Norms Grand Spaulding Dodge.
Re: 340 Block Sleeving Question [Re: Demon340GSS] #1032863
07/18/11 02:40 PM
07/18/11 02:40 PM
orange city,FL
Demon340GSS Offline
Demon340GSS  Offline
orange city,FL
Another Picture.
Grant Eaton 386-561-1181
Re: 340 Block Sleeving Question [Re: Demon340GSS] #1032864
07/18/11 02:44 PM
07/18/11 02:44 PM
orange city,FL
Demon340GSS Offline
Demon340GSS  Offline
orange city,FL
Picture of the top of the cylinders
Re: 340 Block Sleeving Question [Re: Demon340GSS] #1032865
07/18/11 02:51 PM
07/18/11 02:51 PM
orange city,FL
Demon340GSS Offline
Demon340GSS  Offline
orange city,FL
I got a bunch of pics, but here is the last one for now.
Re: 340 Block Sleeving Question [Re: Demon340GSS] #1032866
07/18/11 09:17 PM
07/18/11 09:17 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My dad has cracked a few 340 cylinder walls, NA stock stroke combos, IIRC one of the blocks had even been filled.
68 Barracuda Formula S 340
Re: 340 Block Sleeving Question [Re: Demon340GSS] #1032867
07/19/11 11:53 AM
07/19/11 11:53 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Thanks, Grant. The pictures look great.
That thing should make big power by the looks of your parts list. How soon do you think it will be up and running?
Mo' Farts
