Lets talk about rocker shaft hold downs #1032417
07/14/11 12:29 PM
07/14/11 12:29 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Ive got some knock off pro magnum rockers going on my stealth
Heads. Whats the deal with hold downs? Do i need fancy billet or
Pretty blue anodized ones? And why... Shafts egg shape with stock
Ones? Should i use studs and nuts or bolts? 440 source has fancy
Aluminum holddowns with arp bolts for 60 i think... Good deal? Tell
Me what you have and why thanks!
74 dart sport 440 www.Csucarbs.com
Re: Lets talk about rocker shaft hold downs [Re: shoebox] #1032418
07/14/11 12:38 PM
07/14/11 12:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stock are just that, stock. The ones that came w/my Harland-Sharps are beefy and capture more of the shaft and spread the load greater and studs just make sense.
Re: Lets talk about rocker shaft hold downs [Re: Thumperdart] #1032419
07/14/11 12:50 PM
07/14/11 12:50 PM
tboomer Online work
tboomer  Online Work
I like the ones I bought from Hughes...And Kevin is a good guy to deal with!!
Re: Lets talk about rocker shaft hold downs [Re: tboomer] #1032420
07/14/11 12:59 PM
07/14/11 12:59 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Get the studs...
Re: Lets talk about rocker shaft hold downs [Re: shoebox] #1032421
07/14/11 01:48 PM
07/14/11 01:48 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Here is a pic of the Hughes.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Lets talk about rocker shaft hold downs [Re: Hemi Allstate] #1032422
07/14/11 02:29 PM
07/14/11 02:29 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Are those comp rockers? I need spacers too, those look good
Re: Lets talk about rocker shaft hold downs [Re: shoebox] #1032423
07/14/11 02:30 PM
07/14/11 02:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Spend the little extra on the Hughes ones and you won't be sorry.
Re: Lets talk about rocker shaft hold downs [Re: Stanton] #1032424
07/14/11 03:30 PM
07/14/11 03:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Lets talk about rocker shaft hold downs [Re: 70AARcuda] #1032425
07/14/11 03:42 PM
07/14/11 03:42 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I don want to use hughes stuff ( i have an issue w them) plus ive heard
You have to modify the side width
Re: Lets talk about rocker shaft hold downs [Re: shoebox] #1032426
07/14/11 05:19 PM
07/14/11 05:19 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
with issues with them. But I have there hold down kit it is a good kit and to properly set up rockers you will have to modify any of them you buy !
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Lets talk about rocker shaft hold downs [Re: 65dragnet] #1032427
07/14/11 05:31 PM
07/14/11 05:31 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I got the ones 440 Source offers. Stiffer than stock stamped steel ones and cover more of the rocker shaft so I don't think I am getting as much shaft deflection when they are torqued down.
Old Geezer Racing
Re: Lets talk about rocker shaft hold downs [Re: SCATPACK 1] #1032428
07/14/11 05:36 PM
07/14/11 05:36 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Thanks for the inputs guys
