it is advanced more with the small 2-v carb
if it want less take some out..which you did..let it ride
get a vac gauge and put it on the full vac port on carb
advance it to get the highest vac reading... back it down one full #...if it 18,back it down to 17 on the vac gauge
adjust curb idle to 800-850 rpm,then adjust the air mixture screws on the carb to get highest vac reading on the gauge and adjust curb idle to were you want it set at
use a timeing light and see where the adjustment is at,keep it for referance later.
run it on a wot blast..you want no ping or just a slight ping on a hard wot blast
I do mine this way and get them down to 600-650 rpm and will take a full throttle stomp with out any bog,pop,miss,sputter.(I do have the LD4B/600 carb,VooDoo roller cam,headers,duels,3.55 gears to work with it also)
the thing to do with a stock 318 thats just got a 4-v swap is add duels and fine tune the carb and timeing
find what it likes and run it..cant go by stock book setting once it gets mod-o-fried
to me that is the fun of adding a 4-v to a 318..test & tune baby
