trans or converter prob! #1032144
07/13/11 08:23 PM
07/13/11 08:23 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
well i have an ati 727 that gets freshened every off season,i recently had the converter loosened and reinstalled..car sat with no testing for a month.I was driving today and 2 miles from home,noise from the front of the trans!! clanking etc..made it home trans shifted fine..off to B1JOHNNY it goes
Re: trans or converter prob! [Re: fishy340] #1032145
07/13/11 08:24 PM
07/13/11 08:24 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
and yes it has fluid lol in it!
Re: trans or converter prob! [Re: fishy340] #1032146
07/13/11 08:28 PM
07/13/11 08:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Say it ain't so!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: trans or converter prob! [Re: hemi-itis] #1032147
07/13/11 10:34 PM
07/13/11 10:34 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Did the converter bolts come loose?
Re: trans or converter prob! [Re: rowin4] #1032148
07/13/11 10:43 PM
07/13/11 10:43 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Cracked flexplate.....
Re: trans or converter prob! [Re: abodiesonly1] #1032149
07/13/11 10:50 PM
07/13/11 10:50 PM
Look at the converter bolts and then the flexpalte
Re: trans or converter prob! [Re: Cab_Burge] #1032150
07/13/11 11:28 PM
07/13/11 11:28 PM
ill
dennismopar73 Offline
ill
might go with the cracked flex as well ,, but it could be that the front bearing is spinning in the front pump to
Re: trans or converter prob! [Re: fishy340] #1032151
07/13/11 11:53 PM
07/13/11 11:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Usually when its a flex plate when you get on it and
let off it makes a noise but the bolts tend to make the
noise all the time... and the noise gets worse
Re: trans or converter prob! [Re: MR_P_BODY] #1032152
07/14/11 09:42 AM
07/14/11 09:42 AM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
i will check all of the above,should be easy being i dont have a dust shield the thing that stinks is i didnt even get to flash the converter and see if the stall is 5500 which with pro torque is usualy dead on! thanks boys
Re: trans or converter prob! [Re: fishy340] #1032153
07/14/11 07:58 PM
07/14/11 07:58 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
had one that left me stranded once.. It was the front pump tangs the mesh with the converter to drive the fluid.
Re: trans or converter prob! [Re: Bob_Coomer] #1032154
07/14/11 08:05 PM
07/14/11 08:05 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
well she was fine..before i pulled the converter,we put a moroso deep pan(to lose a few lbs) and we put the conv back in after having it loosened..(im thinkin my brother) didnt tighten something properly (bolts) flex plate or conv we shall see
Re: trans or converter prob! [Re: fishy340] #1032155
07/17/11 10:50 PM
07/17/11 10:50 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
well pulled the drive shaft and checked universial jt,checked bolts for conv,then dumped trans fluid..kinda looked metallic flake..off to b1johnny he will open in front of me shortly!!! awesome guy how many tranny builders let u watch so i will have the answer shortly..hope its not the converter
Re: trans or converter prob! [Re: fishy340] #1032156
08/07/11 10:29 AM
08/07/11 10:29 AM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
prob found in the trans,rear gov supp i think its called...well kinda melted..looks like lack of trans fluid..well with the help of b1 she'll be better,stronger, when he's done its getting some rollerized stuff and a steel drum..so i keep my foot
Re: trans or converter prob! [Re: fishy340] #1032157
08/07/11 01:44 PM
08/07/11 01:44 PM
I have a freind who had a similar problem on melting the rear roller support whiichs ends up hurting other parts The cause was a misalignment of the shifter cable and the cure is proper adjustment of the shifter Make sure the shaft on the shifter cable end slides easily into the shifter arm in all the forward gears, 1st,2nd and high gear If you don't it(the manual valve in the valve body that does ths fluid routing) will restrict the amount of fluid under pressure to the trans and through the trans cooler Take your time and adjust it so it slides in and out easily in those gars, it should drop right in If it does on some and not all adjust the cable in the holding bracket to get it aligned properly, there is usually only ONE place will it will be correct for all three gears You can do it, take your time and be picky
Re: trans or converter prob! [Re: Cab_Burge] #1032158
08/07/11 03:41 PM
08/07/11 03:41 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
thankyou very much,it was kinda puzzeling to us..but that makes sense for sure cause the only thing we did was pull the trans down take conv out and reinstall.. and it was good before!thanks again pal
Re: trans or converter prob! [Re: fishy340] #1032159
08/07/11 04:39 PM
08/07/11 04:39 PM
hemi-itis Offline
hemi-itis  Offline
Time for a custom bonesrollerizerer
