Re: trans or converter prob!
[Re: fishy340]
#1032151
07/13/11 11:53 PM
07/13/11 11:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Usually when its a flex plate when you get on it and let off it makes a noise but the bolts tend to make the noise all the time... and the noise gets worse
[Re: fishy340]
#1032153
07/14/11 07:58 PM
07/14/11 07:58 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
had one that left me stranded once.. It was the front pump tangs the mesh with the converter to drive the fluid.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: fishy340]
#1032157
08/07/11 01:44 PM
08/07/11 01:44 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
prob found in the trans,rear gov supp i think its called...well kinda melted..looks like lack of trans fluid..well with the help of b1 she'll be better,stronger, when he's done its getting some rollerized stuff and a steel drum..so i keep my foot
I have a freind who had a similar problem on melting the rear roller support whiichs ends up hurting other parts The cause was a misalignment of the shifter cable and the cure is proper adjustment of the shifter Make sure the shaft on the shifter cable end slides easily into the shifter arm in all the forward gears, 1st,2nd and high gear If you don't it(the manual valve in the valve body that does ths fluid routing) will restrict the amount of fluid under pressure to the trans and through the trans cooler Take your time and adjust it so it slides in and out easily in those gars, it should drop right in If it does on some and not all adjust the cable in the holding bracket to get it aligned properly, there is usually only ONE place will it will be correct for all three gears You can do it, take your time and be picky
