Page 2 of 3 1 2 3
Re: thrust bearing issues [Re: TheOtherDodge] #1031939
07/13/11 06:34 PM
07/13/11 06:34 PM
If you have space between the converter bolt lugs and the flex plate and DON"T use spacers to fill that gap it will pull the converter forward up agianst the crankshaft Probally causing your problem The converter should not be held against the converter with any tension onto the flex plate I have had to use harden head bolt washers bewtween the flexplate and the converter lugs to avoid prelaoding tension from the converter to the crankshaft, cheap imported cranksahfts I'm guilty of using them
Re: thrust bearing issues [Re: TheOtherDodge] #1031940
07/13/11 06:35 PM
07/13/11 06:35 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
hey, i had the same issue a while ago with a 493. converter wasn't the problem. i wasn't using a cam button. i beleive the cam was was trying to come out of the block( i have heard higher spring pressures can force the cam to come out of the block). if the cam is out, the chain will pull the crank with it.
Re: thrust bearing issues [Re: mac56] #1031941
07/13/11 06:48 PM
07/13/11 06:48 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Make sure main cap thrust surface is not thicker then the block.
Re: thrust bearing issues [Re: supercomp] #1031942
07/13/11 06:51 PM
07/13/11 06:51 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
I don't have any spacers now. The converter is bolted directly to the flex plate.
Unlike big blocks, small blocks have a cam plate to keep the cam from walking forward.
supercomp: explain?
Re: thrust bearing issues [Re: TheOtherDodge] #1031943
07/14/11 12:07 PM
07/14/11 12:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Was it mocked up without the crank, but with the bearings to make sure the thrust surface(s) line up squarely (comparing upper to lower)?
Was the main cap just torqued down, or was the thrust bearing seated first? (referring to forcing the crank forward in the block during torque down)
Either of these can cause an oiling issue. If the bearing shell thrust surfaces are not square with each other, the oil film gets scraped off the thrust surface....
Just throwing a 'maybe' out there
Rich H.
Esse Quam Videri
Re: thrust bearing issues [Re: ZIPPY] #1031944
07/14/11 12:11 PM
07/14/11 12:11 PM
Houston, Texas
Houston, Texas
Zippy, I did not mock up the bearings to check alignment. I did set thrust after final torque, which I thought was the way you are supposed to do it.
Re: thrust bearing issues [Re: TheOtherDodge] #1031945
07/14/11 01:19 PM
07/14/11 01:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I was taught to set thrust/force the crank forward more during torquedown, rather than after.
I can't claim that's perfect info...but that's what the instructors taught me in '88 or whatever it was. It may be flawed somehow for all I know.
Ex: if final torque is 90, then go about 30, set thrust. Do the other caps to the same torque. Verify end play/thrust. Then 60, set thrust again, do the other caps, check the gauge. Then 90, same routine.
Could be converter, but prob. not with that low of boost?
Rich H.
Esse Quam Videri
Re: thrust bearing issues [Re: TheOtherDodge] #1031946
07/14/11 01:47 PM
07/14/11 01:47 PM
How can you set the thrust after all of the main bolts are torque to spec? I torque #1,2,4, and 5 to the final torque specs, it varys with motors. I torque #3 to 20 to 30 Ft lbs and then check the end play, thrust measurement. If within spec I tighten # 3 to final torque specs. and check it again, if it is not within, to little, I use a dead blow hammer and tap (whack it hard ) the crank back and forth to settle the bearings shells in the caps and center them on the main caps, I then check it again If it is okay then I tighten it down and recheck when tight, if not within specs. it is time to figure out why
Re: thrust bearing issues [Re: Cab_Burge] #1031947
07/14/11 02:09 PM
07/14/11 02:09 PM
Houston, Texas
Houston, Texas
"How can you set the thrust after all of the main bolts are torque to spec? "
Why can't you? The crank better not be that tight where you can't set the thrust!
Re: thrust bearing issues [Re: TheOtherDodge] #1031948
07/14/11 02:20 PM
07/14/11 02:20 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You have to set the cap correctly and I don't see how you'd do that with the cap torqued tight to the register. The cap should have enough clearance between the bolt/studs to allow the cap to be aligned with the block,making the bearing aligment correct.
Re: thrust bearing issues [Re: goldmember] #1031949
07/14/11 02:23 PM
07/14/11 02:23 PM
Re: thrust bearing issues [Re: TheOtherDodge] #1031950
07/14/11 02:57 PM
07/14/11 02:57 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I had thrust bearing issues with my old 422 smallblock motor.
The new owner of the car had the motor freshened, and the 727 freshened as well.
The guy who is going through the trans told him he thought the problem with the thrust bearing was because of the line pressure the trans was using( 160), as the transbrake valve body was a Griner and as far as i know is supposed to be set there( the trans i had built by JPT, a long standing expert in performance automatics) i kinda doubt that this guy is correct about the 160 pressure being to high and being the cause.
He told the new car owner the pressure should be about 60
Anyhow, i am unsure what the resolution is or will be.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: thrust bearing issues [Re: goldmember] #1031951
07/14/11 03:35 PM
07/14/11 03:35 PM
Houston, Texas
Houston, Texas
Ok, then I did that wrong, but that is how I have always set it. I guess I got lucky before. I just spoke to the machine shop and they confirmed but said that most likely that did not cause the problem, but is a consideration.
Im going to see if I can drop the pan with the motor in the truck (maybe have to lift it a bit) and look at it and see if I can just replace the thrust bearing.
Also the machine shope echoed the possiblity of line pressure being too high...
Re: thrust bearing issues [Re: TheOtherDodge] #1031952
07/14/11 11:16 PM
07/14/11 11:16 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
line pressure is not the cause. if u lower it, u could smoke the trans. i'm running a 904- 180# 1st, 160# 2nd & 3rd. no thrust problems. stay safe, seeya.
Re: thrust bearing issues [Re: rickraw] #1031953
07/15/11 12:01 AM
07/15/11 12:01 AM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
I'm gonna go out on a limb here, as this is rare...BUT, before you freshened the engine, did you wipe the trans or converter? If so, the crankshaft could be "broke", cracked, whatever you want to call it. The impact from the converter, front pump on trans can break a crank. I know folks whom have seen the same symptoms after a trans failure. PM supercomp...he been there, done that.
Re: thrust bearing issues [Re: TheOtherDodge] #1031954
07/15/11 06:08 PM
07/15/11 06:08 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Transmission line pressure doesn't put pressure directly on the crank but converter pressure does....under normal circumstances the converter pressure is much lower than line pressure.
But, in rare cases, the transmission reaction shaft can spin in its support and shut off the outflow of line pressure from the converter, when this happens the converter pressure regulator valve doesn't function and converter pressure is the same as line pressure.
Re: thrust bearing issues [Re: John_Kunkel] #1031955
07/15/11 06:25 PM
07/15/11 06:25 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
When you get it apart look at the back of the converter and see if it has hit the crank bolts. I had two motors do this and it killed the thrust in both. One turbo car and one procharged car. We had a na car hit too but caught it before the thrust was damaged.
this may not be your problem but is worth checking into.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: thrust bearing issues [Re: 526ciduster] #1031956
07/15/11 09:15 PM
07/15/11 09:15 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
Cab had the right idea about oil problem. The thrust bearing problem is either a bent crank or improper alignment of the main caps. A crank may feel free when you spin it in a new build. Put a lot of pressure on the thrust and any mis-alignment will break up the pressure film of the oil-result-bearing material all over pan. Any race engine must be align honed by good machine shop.
Re: thrust bearing issues [Re: oldtimer5151] #1031957
07/15/11 09:26 PM
07/15/11 09:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Did this on my 498. wiped out the bearing and grooved the crank. Had the crank repaired, put in new thrust bearings, got a NEW torque converter, and never had the prob again.
Re: thrust bearing issues [Re: J_BODY] #1031958
07/23/11 03:03 PM
07/23/11 03:03 PM
Houston, Texas
Houston, Texas
As a follow up, I just have the line pressure checked and it was fine at about 140 lbs.
Page 2 of 3 1 2 3
