Page 4 of 8 1 2 3 4 5 6 7 8
Re: thermoquad VS. Holley 750 DP [Re: rallye73] #1031764
07/17/11 04:12 AM
07/17/11 04:12 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
It's the same reason most morons are into chevs, they just don't know any better! And apart form all this what about all the other problems holleys have, the stripped out threads, the baseplates that are made out of cheese, the fact that the basic design with all the leaks and all the other problems is out of the 50's, the fact that in warm weather they wont start when hot because they boiled over when you turned the engine off, this is a classic, holley couldn't fix it so they gave it a name... "flash boil" the fact that a tiny spec of dirt gets in them and they go haywire. I could go on and on if you guys are happy with junk so be it!
Re: thermoquad VS. Holley 750 DP [Re: gomangoRTSE] #1031765
07/17/11 05:05 AM
07/17/11 05:05 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Geezus I wonder why some people make posts on this subject. When they open their mouth you immediately know they dont know what their talking about.
Put YOUR in and teach us something then, TQ wizard!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: thermoquad VS. Holley 750 DP [Re: joedust451] #1031766
07/17/11 05:21 AM
07/17/11 05:21 AM
Desert Tracker
Desert Tracker
Not talking about the air door, alot of what your saying has nothing to do with what i said , not trying too be a jerk, just saying.
Never SAID you were one!! The air door, I brought up as well as the venturies. They are of a more efficient design than the Holleys', that's
MY point I was getting at, AFTER agreeing with the post!! I just said MY .
Re: thermoquad VS. Holley 750 DP [Re: HYPER8oSoNic] #1031767
07/17/11 08:10 AM
07/17/11 08:10 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Thermoquad, Holley, they're both fuel delivery devices. Both have their good points and falts. They both can be set up to scream or fall on their faces. Holleys main advantage is numbers, there are more of them, and way more aftermarket parts available for them. The Thermoquad was the high water mark for Carter, one Rochester engineer once said the Thermoquad was the next step in development after the quadrajet.
I have Holleys sitting on the shelf from 600cfm units all the way up to 1140cfm and I use them too. I really like the Thermoquad, they're CHEAP, give good mileage, and make great power, and are easy to modify. I can take a 850 thermoquad and modify it and it will run great on a 318 to a stroker Hemi.
One day when I get caught up I'll do some back to back dyno tests with a Thermoquad vs. Holleys. Dave
Re: thermoquad VS. Holley 750 DP [Re: Mcode69] #1031768
07/17/11 09:47 AM
07/17/11 09:47 AM
Delray beach, Florida
P
Performance Only Offline
P
so i guess what should be taken from this thread is what?
most morons like chevies and only a select few people in the world know how to tune a thermoquad?
i've been playing with cars since the 1960's and as i recall, by then the holley 4150's and 4160's had been out for quite some time. the TQ didn't arrive until around 1969. during the years to follow i don't recall many (if any) people touting the TQ as the greatest carb on earth like i see in this thread today. i wonder why that is? to think no one could ever tune one properly would be a ludicrous thought. the argument that they just weren't as popular without an explanation is just crazy talk. if the argument is that they didn't make as many carbs as holley did, well, that's true, but why? if they were the latest and greatest, Carter surely would have made more. right?
they must have some inherent drawback that caused their demise. not only did Chrysler Corporation give up on them, but also the performance crowd of the 70's and 80's etc. so now you'd have one believe that they really are all that and a bag of chips 40+ years later. hasn't history taught us this lesson already?
i've owned a few thermoquads over the years and they performed as well as one could expect. okay mileage, no bogs, etc etc. the fact is none of them ever performed as well as a comparable sized 4150 holley. i never cared for the fact that the primary's are so small that you'd have to put the pedal half way to the floor to get the same acceleration as a 4150 does at less than 1/4 throttle. i never cared for that quadrajet sound of the secondary's opening. some thought it sounded cool, although i didn't. it was mostly noise to me. every car i ever had with a thermoquad eventually got replaced with a holley. the cars drove better and were always faster at the race track. perhaps those are just some of the reasons the thermoquads went the way of the dinosaur. oh, and by the way, don't tell me about holleys that have stripped bolt holes or leaks. we all know what caused the threads to strip out. maybe we can talk about cracked and leaking phenolic carb bodies instead, or some of the other inherent design flaws of the lately much revered thermoquad, or maybe you'd rather not...
machine shop owner and engine builder
Re: thermoquad VS. Holley 750 DP [Re: Performance Only] #1031769
07/17/11 10:20 AM
07/17/11 10:20 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Why not have the best of both worlds.
The spreadbore Holley 6210.
Now everyone can be happy,
not to mention it is a great carb... dbl pumper with 50 cc on secondary, tuneable with small primary.
Re: thermoquad VS. Holley 750 DP [Re: theclutcher] #1031770
07/17/11 10:49 AM
07/17/11 10:49 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
But it looks funny, buckey teeth and its hair sticks up.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: thermoquad VS. Holley 750 DP [Re: Performance Only] #1031771
07/17/11 01:15 PM
07/17/11 01:15 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why didn't the factory engineers put the Holley 750 DP on high performance engines. It was readily available at the time.
- Stu Harmon
Re: thermoquad VS. Holley 750 DP [Re: Performance Only] #1031772
07/17/11 01:34 PM
07/17/11 01:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The TQ was only canned by chrysler because carter went out of buisness due to poor managment, the q-jet filled in for a year and then EFI came out and no more carbs. When the TQ came out it replaced all the holleys, mabey the holleys were so good they just had to replace it with a worse carb When I raced my 66 dart I tried a bunch of different holley carbs and holley style carbs and none had a performance advantage over a t-quad but they all sucked more gas (BTW a 770 street avenger was the closest MPG and ran the same 1/8th mile times) I wish Holley would make an anular booster all aluminum version of the 770 street avenger, it would probably be able to get similar MPG and the only time you would waste fuel is when you change jets. Any one with 1/2 a brain can look down the throat of a carb and see witch one atomizes the fuel better and the TQ does a much better job and that is the real reason they get better MPG, like was mentioned holley covers up the bad transitions by dumping in more fuel. The reason no one ran TQs back in the day is they were convinced it was an emmision piece of junk, same reason no one liked 360s or 400s, no matter how good it was people think it is an emmision only item in spite of the fact they have more potential than the predasessor .
Re: thermoquad VS. Holley 750 DP [Re: feets] #1031773
07/17/11 01:40 PM
07/17/11 01:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
because it was more expensive????? I never said that MPG's wouldn't be better w/ a TQ, however if he has a DP now and it's running well. why muck w/ it? He'll have to BUY a TQ either pay somebody to set it up, or tune it himself and I doubt he'd get more tha 1 maybe 2 mpg's around town better.
Re: thermoquad VS. Holley 750 DP [Re: Performance Only] #1031774
07/17/11 01:43 PM
07/17/11 01:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I dont think many auto makers were using Holleys on much after 1971 or even before that, Carter was always on most GM and Mopars, they needed something that would hold the correct A/F ratio, so in came the QJ and TQ until throttle body injection. Also your statement about Chysler giving up on the thermoquad makes no sense, did they go to bolting up 800/850 Holleys in the mid 80's??? When it comes down to it the QJ and TQ are coming back into favor due to there flexibility and also some guys like to be different. Holley will always be on the majority of hot rods but its more interesting to see a the QJ/TQ getting it done
Re: thermoquad VS. Holley 750 DP [Re: HotRodDave] #1031775
07/17/11 01:57 PM
07/17/11 01:57 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Spell check seemed to be bypassed on this one but at any rate.....I agree with it....and I'll add to it by saying that now we have information that can be shared by the stroke of a keyboard which enables us to more parts, more tuneability, and all around more reason to use a good carburetor like the TQ. There wasn't an information age back in the 70's-80's like there is now and because of this the TQ has come back and IS recognized as a good carb. Many on here will still want a Holley no matter what, but that doesn't make the TQ a bad carb. Again, I have both, and I like both.......
Re: thermoquad VS. Holley 750 DP [Re: 68Bullit] #1031776
07/17/11 04:02 PM
07/17/11 04:02 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Found service manual from a 1000 cfm competition series TQ I ran back in the late 70's.
Back then, I preferred TQ's to the Holley.
Can say it was a nice product and to this day regret selling it as I have not seen another one since.
I imagine that with some tweaking over the yrs, the performance capability of them has improved.
I do remember wishing for more choices of metering rods back then.
Anyone have one of these floating around, 850 or 1000 cfm?
Re: thermoquad VS. Holley 750 DP [Re: theclutcher] #1031777
07/17/11 04:50 PM
07/17/11 04:50 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Several of each, how deep is your wallet?
Seriously, fun carbs to play with but jets can be a challenge short of making/modifying your own, etc. and they are a race oriented version, not the best street manors.
Re: thermoquad VS. Holley 750 DP [Re: HYPER8oSoNic] #1031778
07/17/11 08:22 PM
07/17/11 08:22 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Gotcha
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: thermoquad VS. Holley 750 DP [Re: joedust451] #1031779
07/17/11 10:33 PM
07/17/11 10:33 PM
Desert Tracker
Desert Tracker
Gotcha
CLASSIC!!
Re: thermoquad VS. Holley 750 DP [Re: Performance Only] #1031780
07/17/11 10:55 PM
07/17/11 10:55 PM
Desert Tracker
Desert Tracker
We can spend ALL DAY AND NIGHT posting about both
the Holleys' and the TQs' weaknesses. Sure NEITHER
one is perfect, in design nor in performance and efficiency. Bottom line, it comes down to the matter of which type carb works BEST for the combo at hand .
Re: thermoquad VS. Holley 750 DP [Re: ScottSmith_Harms] #1031781
07/17/11 11:55 PM
07/17/11 11:55 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
My wallet is so deep, you can see Russia when looking at the bottom of it.
Good to see somebody has 'em stashed.... like hens teeth.
Re: thermoquad VS. Holley 750 DP [Re: ScottSmith_Harms] #1031782
07/18/11 12:04 AM
07/18/11 12:04 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
....kind-of 'splains most Berri-Crabs ..
Pig fat, fouling spark-plugs and the air, washing cyl walls .... SHALL I continue ? ..
Re: thermoquad VS. Holley 750 DP [Re: theclutcher] #1031783
07/18/11 12:36 AM
07/18/11 12:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a few of them stashed, finding parts to restore them with is murder so I've grabbed all I could find for a while, I find 10 850's for every 1000, both are scarce but the 1000's are getting rediculous!
