thumper, fenderwell guys exhaust pics wanted #1031604
07/13/11 09:19 AM
07/13/11 09:19 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
i could only stand being out in my shop for 30 minutes last night before there was an outline of sweat on the floor following me wherever i went.
so, research time
i want to see how your exhaust looks and where your muffler ended up
here is where im at
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031605
07/13/11 10:21 AM
07/13/11 10:21 AM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I dont have any pictures but that is the way I ran it on my old 68 Valiant. I ran 3 1/2 inch with bullets and turn outs right in front of the tires. I have another 68 I am working on right now and it will be done the same way except with Turbo mufflers so I can street it. Paint the exhaust flat black and it will blend in with the body.
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031606
07/13/11 10:59 AM
07/13/11 10:59 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
ray ronp has fenderwells and I think his comes out by the back tire! try pm'ing him maybe
Mopar Performance
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031607
07/13/11 11:10 AM
07/13/11 11:10 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Hate 'em, car gets hot....Like real hot. Better have some good insulation on the firewall.
Re: thumper, fenderwell guys exhaust pics wanted [Re: Dragula] #1031608
07/13/11 11:27 AM
07/13/11 11:27 AM
Charleston
Charleston
I was thinking about painting the exhaust flat black, i was hoping to see a pic like that to see what it would look like. the exhaust tubing is alumicoted<sp? , do i need to get that off to paint it?
about the heat, i cant see why it would be any different than exhaust right under the car but i did plan to add some insulation near the exhaust
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031609
07/13/11 11:56 AM
07/13/11 11:56 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My dumb ass can`t figure out the picture posting thing but mine are similar to yours w/the bullets dumping before the tires which I hate in case my motor pukes it`s guts which could get ugly. If you look closely at my photo you`ll see em.
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031610
07/13/11 01:02 PM
07/13/11 01:02 PM
Butler Pa. USA
rickma Offline
rickma  Offline
Butler Pa. USA
my 69 dart
Re: thumper, fenderwell guys exhaust pics wanted [Re: rickma] #1031611
07/13/11 01:03 PM
07/13/11 01:03 PM
Butler Pa. USA
rickma Offline
rickma  Offline
Butler Pa. USA
69 dart
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031612
07/13/11 01:30 PM
07/13/11 01:30 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
so, research time
here is where im at
My old exhaust looked similar. I am in the process of going to 3.5" all the way also. Using Magnaflow race mufflers. Only I'm using stainless the whole way. Will dump it out in front of the tires. I'd love to take it to the back bumper, but that would be nearly impossible. Not too much you can do with big tubing.
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031613
07/13/11 02:12 PM
07/13/11 02:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
so, research time
here is where im at
I had mine( 3 inch pipes) ran to the rear of the car, the pipes go UNDER the rear end housing (no room to go over the rear end housing because of the coil overs and stock A body gas tank ) and the muffs are mounted between the rear sub frames and rear fenders. The tail pipes from the mufflers are about six inches long bent at a 45 degree down angle, thier mounted so the mufflers exit at the rear bumper, no noise under the car Noise is good at part throttle in the car, everyone that has heard it on the street and at the races says that it sounds really good, mellow and so on The muffs are a set of Magnaflow 3 x 14 inch ovals, side entrance center exit straight through I gained .04 ET and .25 MPH by dropping the entire system off of the car at the local 1/8 track, probally due to the weight loss, not back pressure (I switch headers several years ago from a set of Hooker A body 2 inch primarys fenderwells to a set of Hedman 2 inch primary fenderwells coated black for the Indy heads,not silver like the Hookers are in this picture ) This pcture is before changing the headers so you can't see what I'm talking about, the black coating hides the pipes from most people and also hides the ladder bars You might want to think of using the oval pipes from the headers back to the muffs instead of the round pipes I'm thinking of switching from the 3 inch system to a 3.5 inch system(Spintech makes the pipes and reducers ) and going to the oval pipes at the same time
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031614
07/13/11 02:22 PM
07/13/11 02:22 PM
PA
moparacer Offline
moparacer  Offline
PA
so, research time
here is where im at
I have that exact same setup on my car with 3 1/2 bullets.
Will see if I have some pictures.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: thumper, fenderwell guys exhaust pics wanted [Re: moparacer] #1031615
07/13/11 02:37 PM
07/13/11 02:37 PM
PA
moparacer Offline
moparacer  Offline
PA
Here is my setup. Really quieted the car down and didn't hurt the ET a bit.
Re: thumper, fenderwell guys exhaust pics wanted [Re: moparacer] #1031616
07/13/11 02:38 PM
07/13/11 02:38 PM
PA
moparacer Offline
moparacer  Offline
PA
Other side.
Re: thumper, fenderwell guys exhaust pics wanted [Re: moparacer] #1031617
07/13/11 03:12 PM
07/13/11 03:12 PM
Charleston
Charleston
that looks good. looks like yours tucks up there better than mine does. i like the look of the turn outs but was also thinking about a straight pipe that i could put those cone baffles in it to quiet it down
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031618
07/13/11 05:11 PM
07/13/11 05:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine were 3.5 pipe to bullits and turndowns pointed under the car.
Picked up .15 and almost four MPH building my own headers.
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031619
07/13/11 05:20 PM
07/13/11 05:20 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Here's my junk
Easy removal with 1 band clamp and 1 bolt through the frame connector.
Don't tuck up as nice because I used the Dymomax Ultra Flow 6" round by 16" long cans with 3 1/2 inlet & outlet.
Used a 18" slip on collector then the muffs after that about 2' of pipe with some 3 1/2" turndowns after the muffs.
I personally like the sound over the bullets (loud) The turndowns also aided in quieting the exhaust.
Re: thumper, fenderwell guys exhaust pics wanted [Re: roadhazard] #1031620
07/13/11 05:25 PM
07/13/11 05:25 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
ray can you do pro parts style? or do you have the headers already?
Mopar Performance
Re: thumper, fenderwell guys exhaust pics wanted [Re: moparniac] #1031621
07/13/11 06:39 PM
07/13/11 06:39 PM
Charleston
Charleston
i have headmans because i think they are better than the proparts. shorter pri length, collector starts in the wheel well and is actually, maybe 16" long as is
Roadhazzard, i have the same muffs and was thinking about putting my muffs in the same spot as yours because i could tuck them up better but some have said it would be quieter the further back i put them. how load is your car?
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031622
07/13/11 10:10 PM
07/13/11 10:10 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
im not a big fan of the exhaust dumping in front of the rear tire....any motor issue and you got oil all over the rear tires....my
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031623
07/13/11 10:34 PM
07/13/11 10:34 PM
Here is a current picture of my car with the Hedmans for the Indy heads and the non coated extension I had to have made to hook the Hedmans to the old (current) 3 inch exhaust system
