thumper, fenderwell guys exhaust pics wanted
#1031604
07/13/11 09:19 AM
07/13/11 09:19 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i could only stand being out in my shop for 30 minutes last night before there was an outline of sweat on the floor following me wherever i went.
so, research time i want to see how your exhaust looks and where your muffler ended up
here is where im at
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: thumper, fenderwell guys exhaust pics wanted
[Re: sixpackgut]
#1031607
07/13/11 11:10 AM
07/13/11 11:10 AM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
Hate 'em, car gets hot....Like real hot. Better have some good insulation on the firewall.
[Re: Dragula]
#1031608
07/13/11 11:27 AM
07/13/11 11:27 AM
sixpackgut
Charleston
I was thinking about painting the exhaust flat black, i was hoping to see a pic like that to see what it would look like. the exhaust tubing is alumicoted<sp? , do i need to get that off to paint it?
about the heat, i cant see why it would be any different than exhaust right under the car but i did plan to add some insulation near the exhaust
[Re: sixpackgut]
#1031612
07/13/11 01:30 PM
07/13/11 01:30 PM
Posts: 2,360 PA
70HemiGTX
PA
here is where im at
My old exhaust looked similar. I am in the process of going to 3.5" all the way also. Using Magnaflow race mufflers. Only I'm using stainless the whole way. Will dump it out in front of the tires. I'd love to take it to the back bumper, but that would be nearly impossible. Not too much you can do with big tubing.
[Re: sixpackgut]
#1031613
07/13/11 02:12 PM
07/13/11 02:12 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
here is where im at
I had mine( 3 inch pipes) ran to the rear of the car, the pipes go UNDER the rear end housing (no room to go over the rear end housing because of the coil overs and stock A body gas tank ) and the muffs are mounted between the rear sub frames and rear fenders. The tail pipes from the mufflers are about six inches long bent at a 45 degree down angle, thier mounted so the mufflers exit at the rear bumper, no noise under the car Noise is good at part throttle in the car, everyone that has heard it on the street and at the races says that it sounds really good, mellow and so on The muffs are a set of Magnaflow 3 x 14 inch ovals, side entrance center exit straight through I gained .04 ET and .25 MPH by dropping the entire system off of the car at the local 1/8 track, probally due to the weight loss, not back pressure (I switch headers several years ago from a set of Hooker A body 2 inch primarys fenderwells to a set of Hedman 2 inch primary fenderwells coated black for the Indy heads,not silver like the Hookers are in this picture ) This pcture is before changing the headers so you can't see what I'm talking about, the black coating hides the pipes from most people and also hides the ladder bars You might want to think of using the oval pipes from the headers back to the muffs instead of the round pipes I'm thinking of switching from the 3 inch system to a 3.5 inch system(Spintech makes the pipes and reducers ) and going to the oval pipes at the same time
[Re: moparacer]
#1031615
07/13/11 02:37 PM
07/13/11 02:37 PM
Posts: 2,497 PA
moparacer
PA
Here is my setup. Really quieted the car down and didn't hurt the ET a bit.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#1031617
07/13/11 03:12 PM
07/13/11 03:12 PM
sixpackgut
Charleston
that looks good. looks like yours tucks up there better than mine does. i like the look of the turn outs but was also thinking about a straight pipe that i could put those cone baffles in it to quiet it down
[Re: sixpackgut]
#1031619
07/13/11 05:20 PM
07/13/11 05:20 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Here's my junk Easy removal with 1 band clamp and 1 bolt through the frame connector. Don't tuck up as nice because I used the Dymomax Ultra Flow 6" round by 16" long cans with 3 1/2 inlet & outlet. Used a 18" slip on collector then the muffs after that about 2' of pipe with some 3 1/2" turndowns after the muffs. I personally like the sound over the bullets (loud) The turndowns also aided in quieting the exhaust.
[Re: roadhazard]
#1031620
07/13/11 05:25 PM
07/13/11 05:25 PM
Posts: 6,295 U.S.
moparniac
U.S.
ray can you do pro parts style? or do you have the headers already?
Mopar Performance
[Re: moparniac]
#1031621
07/13/11 06:39 PM
07/13/11 06:39 PM
sixpackgut
Charleston
i have headmans because i think they are better than the proparts. shorter pri length, collector starts in the wheel well and is actually, maybe 16" long as is
Roadhazzard, i have the same muffs and was thinking about putting my muffs in the same spot as yours because i could tuck them up better but some have said it would be quieter the further back i put them. how load is your car?
[Re: sixpackgut]
#1031622
07/13/11 10:10 PM
07/13/11 10:10 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
im not a big fan of the exhaust dumping in front of the rear tire....any motor issue and you got oil all over the rear tires....my cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: sixpackgut]
#1031623
07/13/11 10:34 PM
07/13/11 10:34 PM
Cab_Burge
Here is a current picture of my car with the Hedmans for the Indy heads and the non coated extension I had to have made to hook the Hedmans to the old (current) 3 inch exhaust system
[Re: sixpackgut]
#1031626
07/14/11 12:40 AM
07/14/11 12:40 AM
Cab_Burge
is it painted black because i cant see an exhaust in the pic. i like the stripe on the car
Hedman coated the headers, they are black Local shop did the pipes and mufflers, black also. Stealth mode, you know Thanks for the compliment on the stripes, it does help it some
[Re: rickma]
#1031627
07/14/11 01:08 AM
07/14/11 01:08 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
69 dart
Rickma,
Which Headers are those? I have proparts for my Cuda, but was thinking about going with something different.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: cheapstreetdustr]
#1031630
07/14/11 02:40 AM
07/14/11 02:40 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
cheapst.
I didnt really think of it like that ever, but now when it comes time to do my exhaust, im not dumping it out the side. Fenderwell headers go in tomorrow hopefully
