Headers for a 1968 Dart with 440-1 Heads #1031270
07/12/11 09:07 PM
07/12/11 09:07 PM
pro99 Offline OP
pro99  Offline OP
I hope this is in the rite spot.
OK after going through tons of post and not really finding what I need I'll just ask and get kicked in the head for this post
If you know of a good post or can just tell me that would be great.
What I'm looking for is a set of headers (biggest tube) that will fit in a 1968 Dart with 440-1 heads on a 440 motor (MRE 540 block) with a factory K-member and using a front engine plate. The car is m/s m/b with a 727 auto. If theres anymore info needed I will get to you so I can get the best header for this car.
1968 Dart Drag Car (I just bought it)
Re: Headers for a 1968 Dart with 440-1 Heads [Re: pro99] #1031271
07/13/11 03:47 AM
07/13/11 03:47 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Might want to post in the race section,,, but I'm guessing the aprons are coming out.
Re: Headers for a 1968 Dart with 440-1 Heads [Re: RemCharger] #1031272
07/13/11 10:23 AM
07/13/11 10:23 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
TTI or custom made
Re: Headers for a 1968 Dart with 440-1 Heads [Re: DaKuda] #1031273
07/13/11 10:31 AM
07/13/11 10:31 AM
Super Scamp Offline
Super Scamp  Offline
TTI or custom made
Just get a custom set made or order the TTI they will be a fight to get them in just ask me why.
Just One Man's Opinion Mopar Mafia Racing
Re: Headers for a 1968 Dart with 440-1 Heads [Re: Super Scamp] #1031274
07/13/11 11:16 AM
07/13/11 11:16 AM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
Cant Gary make you a set? Just asking
Re: Headers for a 1968 Dart with 440-1 Heads [Re: BB Dart 69] #1031275
07/13/11 11:56 AM
07/13/11 11:56 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
A friend of mine put 2" tti's on a 500 RB and he had to notch the shock support on the passenger side.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Headers for a 1968 Dart with 440-1 Heads [Re: deaks] #1031276
07/13/11 01:28 PM
07/13/11 01:28 PM
maryland
freebirdsmopars Offline
maryland
stahlheaders.com the best you can get....not cheep,but last forever!
Re: Headers for a 1968 Dart with 440-1 Heads [Re: pro99] #1031277
07/13/11 02:37 PM
07/13/11 02:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
I bought a set of Hedman race headers (no flanges for the collectors to bolt to) for my car(1971 Duster with a BB) when I bought the Indy heads, call Hedmans race shop # in Georgia to get the part number Sorry for not having it, Google Hedman Headers, the race shop number is in the contact information The Hedmans fit a lot better than the Hookers I had did, the Hookers rub the front tires more, the Hedmans are tuck in tighter to the inside of the fenderwells IHTHs BTW, Hedman makes two different sets of headers for the BB A body Mopars, one for standard heads and one for the Indy heads I bought mine form Summit, have them drop ship them to you directly, Summit does not stock them, they are custom made by Hedman when you order them Hedman will coat them also, way cheaper than anyone else I could find Nice coating, I used black, hard to see them in the car from the sides this picture is of my car before switching to the Hedmans, the Hookers are Jet Hot coated and the exhaust pipes(under the car rocker panels all the way back and go under the rear end hosuing are coated black The side pipes hide the ladder bars also the Hedmans are really nicely finished and fit well
Re: Headers for a 1968 Dart with 440-1 Heads [Re: pro99] #1031278
07/13/11 04:22 PM
07/13/11 04:22 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
There is an abundance of capable fab shops in the Detroit-Metro area that can build you a set. The last set I did, I had about $600. in materials. Plus labor. Plus powder coating. You have to realise that when you put a motor in using a motor plate etc. your gonna create variation in how well these shelf headers work.
Re: Headers for a 1968 Dart with 440-1 Heads [Re: HardcoreB] #1031279
07/13/11 06:26 PM
07/13/11 06:26 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Custom headers are the ONLY way to go. Mine are 2" to 2 1/8" stepped fenderwell headers that my friend made for me from Hooker flanges and tubing that I bought from Jegs.
Here's why they are worth every penny:
I can remove them from the car in less than 1/2 hr.
I can replace the starter in about 10 minutes. (nothing is in the way)
There is not a single ding, dent, or sharp bend on them.
When I put the car on the rear bumper in Chicago (wheelie bars were in the trailer ) I dinged the oil pan and tranny pan, but did not touch the headers.
I can load/unload my car on any open or enclosed trailer and the headers will not drag or hang the car up.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Headers for a 1968 Dart with 440-1 Heads [Re: nhramark] #1031280
07/13/11 09:39 PM
07/13/11 09:39 PM
pro99 Offline OP
pro99  Offline OP
Thanks everyone for the info and I will look into custom to Hooker to Headman.Does anyone have a name of a shop that can build a set when the motor is in and finished?
Re: Headers for a 1968 Dart with 440-1 Heads [Re: pro99] #1031281
07/13/11 10:46 PM
07/13/11 10:46 PM
Look at sixpakgut post on headers, I added two pictures to it instead of this one My bad Side picture with Hedmans.
Re: Headers for a 1968 Dart with 440-1 Heads [Re: Cab_Burge] #1031282
07/13/11 10:48 PM
07/13/11 10:48 PM
Engine pictture of Hedmans for Indy heads using SR instead of the 440-1 heads with a low deck block
Re: Headers for a 1968 Dart with 440-1 Heads [Re: Cab_Burge] #1031283
07/14/11 08:05 AM
07/14/11 08:05 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
In most applications the The 2" Hooker and Hedman fenderwell headers work.They range from $500 to $750.Custom headers run from $800 to $1000 for larger tube and coated.
Re: Headers for a 1968 Dart with 440-1 Heads [Re: B G Racing] #1031284
07/14/11 08:12 AM
07/14/11 08:12 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Go with the custom headers for the few bucks more. Better fit and better material.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Headers for a 1968 Dart with 440-1 Heads [Re: slippery440] #1031285
07/19/11 10:26 AM
07/19/11 10:26 AM
pro99 Offline OP
pro99  Offline OP
Does anyone know of a good Place in Michigan to get custom headers done?
Re: Headers for a 1968 Dart with 440-1 Heads [Re: pro99] #1031286
07/19/11 12:50 PM
07/19/11 12:50 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
Diamond Fabrication on Groesbeck, North of ten mile on the east side
Re: Headers for a 1968 Dart with 440-1 Heads [Re: BB Dart 69] #1031287
07/19/11 12:52 PM
07/19/11 12:52 PM
pro99 Offline OP
pro99  Offline OP
Thanks Mark
Re: Headers for a 1968 Dart with 440-1 Heads [Re: pro99] #1031288
07/19/11 01:29 PM
07/19/11 01:29 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
www.SeanSexhaustShop.com!!!
Re: Headers for a 1968 Dart with 440-1 Heads [Re: HardcoreB] #1031289
07/19/11 02:34 PM
07/19/11 02:34 PM
Commerce, Michigan
EasyG Offline
EasyG  Offline
Commerce, Michigan
I've been there!
