Fuel supply issues and results #1031070
07/12/11 03:32 PM
07/12/11 03:32 PM
Cab_Burge Offline OP
I had posted a problem I found with my LM1 on my current Duster engine last week, it would go lean from the hit of the throttle. The motor is a pump gas 518 C.I. 400 block with dished pistons, I had changed the heads, intake and carbs from the last time I had this motor in the car. The motor did not miss, surge, lay down or give me aany indication that it was starving for fuel, it did not run the same MPH as other cars with similar weight and ET The wide ban showed it starting the run at 12.8 and going to 15.8 AFR at the end of the 1/4 mile runs at Woodburn several week ago I ended up checking the size of the needles and seats in the carb.it is a stock Holley 850 CFM D.P. 4781-7, it had .110 needles and seats so I changed them to a set of .120 (8.25 % increase in size)last week before the race at Madras, the car had ran a best of 6.786 ET and 101.58 MPH with a air density of 3975 FT. one month ago before the change. This past weekend it ran a best of 6.643 ET at 102.97 MPH with the air density at 4501 FT with no other changs than the bigger needles and seats My message is to make sure all of the fuel system parts are big enough and in good enough condition to feed your motor enough fuel so that you can jet the carb. up big enough to slow the car down, which I will do in two weeks at Woodburns Mopar race. If you go stop by and say hello
Re: Fuel supply issues and results [Re: Cab_Burge] #1031071
07/12/11 04:17 PM
07/12/11 04:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup you can't make power without fuel and few people really know how to deliver it.
Re: Fuel supply issues and results [Re: Cab_Burge] #1031072
07/12/11 09:31 PM
07/12/11 09:31 PM
NC
440Jim Offline
440Jim  Offline
NC
I have to admit, that wide band mixture logged data is helpful for trouble shooting. Good work on your part.
Re: Fuel supply issues and results [Re: 440Jim] #1031073
07/12/11 09:59 PM
07/12/11 09:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So true Jim, one of the best items I`ve bought in a long time and it shows even the smallest of changes as Cab posted. Don`t you run a wideband?
Re: Fuel supply issues and results [Re: Thumperdart] #1031074
07/13/11 11:51 PM
07/13/11 11:51 PM
Torrance, Ca
Fig Offline
Fig  Offline
Torrance, Ca
Snake oil or do these work better than the standard needle and seat?
"CARP" Needle & Seat.
http://www.4secondsflat.com/fbo__et_slayer_carburetors.htm
1937 Plymouth R/S Coupe
440/727
Re: Fuel supply issues and results [Re: Fig] #1031075
07/14/11 12:27 AM
07/14/11 12:27 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve visited that site and it makes sense because fuel enters through the bottom instead up up top.
