Victor head gasket coolant holes? #1030561
07/11/11 10:05 PM
07/11/11 10:05 PM
Canada
demon Offline OP
demon  Offline OP
Canada
The Victor head gaskets for my 440 don't have all the coolant holes to match to the heads. There are only 3 slots at the top instead of open holes at the top and bottom. What's the deal? I can't see how blocking holes off can help cooling
Re: Victor head gasket coolant holes? [Re: demon] #1030562
07/11/11 11:41 PM
07/11/11 11:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You'll be fine, leave'em alone,...I guess you just missed the thread regarding the cooling slots on BBlk head gaskets
Re: Victor head gasket coolant holes? [Re: DAYCLONA] #1030563
07/11/11 11:56 PM
07/11/11 11:56 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Here is the ORIGINAL head gasket from my 383 , has a 18XXXXX part number. My 383 HP never had a heat issue for the few thousand miles I put on it , 22" factory 3 core rad , shroud , 7 blade fixed fan , 3.91 gears , 65 on the highway with 90 degree heat was never an issue .
Re: Victor head gasket coolant holes? [Re: JohnRR] #1030564
07/12/11 04:59 PM
07/12/11 04:59 PM
Canada
demon Offline OP
demon  Offline OP
Canada
So I guess this design was an update perhaps to restrict coolant flow thru the heads to even out temperatures.
I'll just carry on then
