Transmission Leak???? #1030372
07/11/11 07:37 PM
07/11/11 07:37 PM
USA
JoesMopar Offline OP
USA
I've noticed when I park my car there will be a huge puddle of transmission fluid under the car after it sits awhile. It only does it when the car sits for awhile, not overnight, not 2 days, not a few hours..only when it sits for roughly 4 or more days without getting started up or driven. Does this make sense to anyone and where could it be coming from that it "waits" to start leaking?
Car is a '77 Fury A38 with 440/727.
Re: Transmission Leak???? [Re: JoesMopar] #1030373
07/11/11 07:43 PM
07/11/11 07:43 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
Probably converter drain-back. And more likely from where the valve-body sticks-out in the case. But have you checked ?
Re: Transmission Leak???? [Re: BeEtLeJuIcE !] #1030374
07/11/11 07:46 PM
07/11/11 07:46 PM
USA
USA
I just did a quick check and it looked somewhere around the front of the transmission, not done a thorough check yet as I'm working on another car at the moment....just looking for quick advice so when I get this thing in the air I can figure on it being quick and easy or long and tedious....
Re: Transmission Leak???? [Re: JoesMopar] #1030375
07/11/11 07:52 PM
07/11/11 07:52 PM
Florida STAYcation
Florida STAYcation
Clean that shifter/VB area with brake clean and then sprinkle it with baby powder. THIS will show any leaks.
Re: Transmission Leak???? [Re: BeEtLeJuIcE !] #1030376
07/11/11 07:54 PM
07/11/11 07:54 PM
USA
USA
Thanks again
Re: Transmission Leak???? [Re: BeEtLeJuIcE !] #1030377
07/11/11 08:50 PM
07/11/11 08:50 PM
scratchnfotraction Offline
this works every time
Re: Transmission Leak???? [Re: scratchnfotraction] #1030378
07/11/11 11:08 PM
07/11/11 11:08 PM
W this came up prior someone posted a good trick on how to get the baby powder up there. Any body remem what it was? Some type of applicator
