Aftermarket A/C System
#1030351
07/11/11 07:02 PM
07/11/11 07:02 PM
Posts: 109 Texas
Knappy
Texas
I want to put an aftermarket A/C system in my 71 Challenger Convert. Originally a 318 A/C car. I am going to put a 440 6-pack in it. Does anyone have any experience with these all in one systems? I would like to hide the compressor under the engine. Is there any such systems out there?
Steve
68 Coronet R/T Hemi 70 Challenger 440-6 70 Challenger R/T S/E 440-6 71 Challenger Convert. 70 Superbird 440-6
Re: Aftermarket A/C System
[Re: Knappy]
#1030353
07/11/11 09:05 PM
07/11/11 09:05 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
It's hard to tell my 1970 440-6 Shaker hood car has A/C when looking under the hood or inside the car, unless you know what your looking for.
Bouchillion for the pump and under alternator mounting bracket. You have to run an electric fuel pump. I did reroute the fan belts from their design to increase the amount of contact on the compressor pulley. I also upgraded the alternator from the one shown here.
Nostalgic air for the reciever/dryer & largest multi-pass condensor that fits in front of the entire radiator opening. Lines sourced locally from an A/C supply shop. I used black lines to keep them hidden. Cut them to fit, marked them for index them and then took them down to be crimped.
Inside the car, Vintage Air Gen IV Sure Fit is the only real choice.
[Re: bri440]
#1030355
07/11/11 10:45 PM
07/11/11 10:45 PM
Andrewh
I cannot speak specifically on an e-body, 440, or hidden a/c. I can speak of adding a/c to a convertible living in texas.
I used the classic auto air system in a 65 coronet convertible. The system functions well, cooling pretty well based on air temp differences. 30 degrees as I recall last time I checked.
With the top up, windows up, in 100 degree weather, it keeps me from sweating, but just barely. It never kept me cool.
with the top down, you don't even feel a cool breeze.
This is probably the worst money I ever spent.
If I take the car out, I want the top down. IF it is too hot for that, I don't drive it.
you may have different motivation for driving yours, but wanted to give you an opinion.
It is not the same as a modern car, and even those don't move enough air with the windows open. I checked, incase it was just a bad system thinking it wasn't moving as much air. not having on old a/c system to try, I can only go by memory thinking the original a/c I had in a 66 blew colder air and moved more of it, but memory is a tricky thing. for all I know it was just as bad.
[Re: bri440]
#1030356
07/12/11 03:47 AM
07/12/11 03:47 AM
jbc426
West Coast, USA
I looked at the Bouchillion kit - looked nice, but expensive. I made a plate that attached to the mechanical fuel pump holes ( I also kept the blocking plate to seal the hole) and welded a set of the universal brackets onto the plate. The main benefit (aside from cost) was that I could put a full size compressor in, not the "Shorty" that Bouchillion sells. I attached a second bracket from the other side of the compressor ears to the motor mount to triangulate everything for a solid mount. With the longer compressor, I had to move the alternator forward and actually run the alternator off the second compressor pulley. If you can fabricate the compressor mount, changing the alternator isn't hard.
Good Luck
Sounds good. Is it easy to adjust the belt tension? Can you post a picture of your mount?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Knappy]
#1030357
07/12/11 09:03 AM
07/12/11 09:03 AM
Challenger 1
Cincinnati, Ohio
I did this same conversion in 2005. I mounted mine up top so I could use stock fuel pump and vapor separater. Those items were important to me for reliable operation without vapor lock in hot weather. I hate electric fuel pumps for the street. I used all new stuff under the hood from Bouchillon. Used all the stock stuff inside the car. It works fine with plenty of air movement. I rebuilt my stock AC/heat box with new heater core and evaporator and gaskets. I have heard the replacement AC boxes may move less air? I have 2 cars done like this and drove my BLACK 340 car over the weekend and it sure was nice having AC when it's hot and humid outside. I doubt that I could get the wife to go with me without it.
