41 plymouth grille custom inserts #1030250
07/11/11 04:50 PM
07/11/11 04:50 PM
elkhart, indiana, usa
grizzley155 Offline OP
i see lot of inserts available for older plymouths. has anyone seen a place that will make a new insert for my 41 coupe?
Re: 41 plymouth grille custom inserts [Re: grizzley155] #1030251
07/11/11 06:09 PM
07/11/11 06:09 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Where have you seen inserts for other years?
Re: 41 plymouth grille custom inserts [Re: RodStRace] #1030252
07/11/11 07:47 PM
07/11/11 07:47 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Grille inserts for older Mopars
http://www.alumicraft.com/alumicraft_web/Alumicraft_Stx.html
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: 41 plymouth grille custom inserts [Re: 36PLYM] #1030253
07/11/11 09:02 PM
07/11/11 09:02 PM
www.srpmstreetrods.com alot of nice parts but not for 41
Re: 41 plymouth grille custom inserts [Re: 36PLYM] #1030254
07/11/11 09:03 PM
07/11/11 09:03 PM
Re: 41 plymouth grille custom inserts [Re: grizzley155] #1030255
07/18/11 07:59 PM
07/18/11 07:59 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Howdy guys. I normally just cruise through some of the stuff on here and don't post much but I thought that I would throw this out there. I have been doing custom fabrication and restoration work for a very long time and yes I can custom fab anything you may want or need. Grill inserts are not a problem either. Stainless steel or aluminum or chrome plate work is all ok by me. Here is a photo of my latest project that I did for one of my customers. A polished aluminum bumper, brackets, mid valance and the lower valance for a 1963 Max Wedge Dodge. These all started out as just flat pieces of alloy sheet. I specialize in difficult compound shapes and have the proper equipment to do the job right. Cheers! JC.
Re: 41 plymouth grille custom inserts [Re: QuickSilver] #1030256
07/20/11 08:56 PM
07/20/11 08:56 PM
ty for the reply jc, your work looks great. as you can tell my project is a one of a kind. im looking for something unique. the original 41 grille was just to plain . im looking for a set of shark teeth that mirror each other. the opening are rough and i want the inserts to give a finished look .i hope that doesn't sound to strange lol. bill
Re: 41 plymouth grille custom inserts [Re: QuickSilver] #1030257
07/22/11 10:51 PM
07/22/11 10:51 PM
what would you need from me to make a grill for me? i see your in michigan. im in the southbend area in indiana. the replacement inserts that are available for the old plymouths are really nice. would you interested in making me one?
Re: 41 plymouth grille custom inserts [Re: grizzley155] #1030258
08/04/11 08:30 AM
08/04/11 08:30 AM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Thanks for the kind words there Bill. I don't come on here so much when things are busy. I can build what ever you want. Normally I work on a time plus materials basis and some of these deals can get rather involved. A simple drawing of what you are thinking about would give me some idea of what it is you are after. It can be a simple flat shape of shark teeth on up to something 3d and very elaborate. OF course there is the materials to consider as well as the finish on them. Polished stainless or alloy or plated steel it really is up to you. I made a grill insert for a 1951 Jag XK120 roadster that I restored. It was brass that was chrome plated and it turned out beautiful. I basically took what was left of three original grills to make one nice unit so anything can be done. Thanks, JC.
Re: 41 plymouth grille custom inserts [Re: QuickSilver] #1030259
08/06/11 04:11 PM
08/06/11 04:11 PM
jc, i would unbolt the front end and bring it to you, if it meant getting a new look on my car. right now i have perferated steel behind the opening, the original opening is so rough .the original stainless trim was about a inch wide ,and i just wanted to get a new look. do you mind telling me where you are located? i can bend a sheet of material that would hold the shape and the size but it would be better if you had the front to fit it to. bill
Re: 41 plymouth grille custom inserts [Re: QuickSilver] #1030260
08/14/11 02:25 AM
08/14/11 02:25 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
nice work,, you need to change ur screen name to metal wizard,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
