Wedge race block availablity? And New bullet idea's
#1029997
07/10/11 11:57 PM
07/10/11 11:57 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
OK What the deal with the aftermarket blocks now? Last I heard World has stopped Production.. Maybe Zippy will chime in? So the plan is to build a large Bore 4.5 minimal moderate stroke, and moderate compression and add some spray... Im thinking a 540" with a 4.5 bore and a 4.25 stroke, nice light pistons, rods good crank and spray it 250+... entry level 440-1 heads, but from scratch a B1 Original probably isnt much more money is it? My goal isnt to crazy, make 800+ on motor and have 1000+ on spray. See how fast I can get a 2750 lb car to go... Of coarse on Radials
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Wedge race block availablity? And New bullet idea's
[Re: Bob_Coomer]
#1029998
07/10/11 11:59 PM
07/10/11 11:59 PM
Bob_Coomer
Rock Springs
Let me add that the World hemi block I used was very nice, I sure hoped I havent missed the boat with a Wedgie version. The Indy Maxx block was nice too..
[Re: PC-CHARGER]
#1030002
07/11/11 01:32 AM
07/11/11 01:32 AM
Posts: 903 Saskatchewan, Canada
cudabin
I vote for the Kieth Black Block! Ken is a stand up guy, and the casting quality is way better than the Indy stuff...
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Bob_Coomer]
#1030003
07/11/11 06:04 AM
07/11/11 06:04 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
B1WES built exactly what you need! A KB block, mildly ported B1 head motor, low deck 4.500 bore, 4.25 stroke single four setup. The new owner still is on this board. Motor made 914 hp all motor. It was built for spray, and flew once the juice was put to it. can,t remember how fast, but deep into the 8s at 3400 lbs. I put one pass on the car during initial shake down runs out in Phoenix AZ. Went 9 teens in the thin air out there. Basic B1 540 with a plate ought to push you to low eights.
[Re: sg66mopar]
#1030004
07/11/11 10:32 AM
07/11/11 10:32 AM
Posts: 190 Winterpeg, Canada
hvyweight
Winterpeg, Canada
Bill Mitchell JR. still has them on eBay. That's where I bought mine last fall.
http://cgi.ebay.com/World-Products-Wedge...=item3f00f19ee3
I also purchased this exact block. It requires a fair amount of work to make it right. FYI you can run a standard cam. The lifters will be near the edge of the lobe. You will need a .200 lifter, I used ISKY EZ roll. I am not sure about the quote of priority main oiling? Also if you order it with lifter bushing you may require smaller hole for pushrod oiling. Also I had a terrible time trying to seal the rear main. Finally installed a rope seal and no leaks! With my nitrous cam and B1MC's it made just short of 900 on my buddies dyno if that means anything. It made alot of torque 840 ft/lbs. I hope to be spraying on the chassis dyno this week!
Mike
[Re: Bob_Coomer]
#1030007
07/11/11 11:48 AM
07/11/11 11:48 AM
Posts: 17,897 S.E. Michigan
ZIPPY
S.E. Michigan
OK Maybe Zippy will chime in?
ok...
On the Mopar side of things:
P5153860AB 4.50 finish bored, 33 in stock
P5153944AB 4,31 rough bored, 1 on backorder, 4 in transit (will be 3 in stock after the existing order is filled)
These are iron....
[Re: FastmOp]
#1030009
07/11/11 07:52 PM
07/11/11 07:52 PM
Bob_Coomer
Rock Springs
Thanks for the reply's guys.. Quote:
Only thing I can add is put more stroke in it. I love my 4.5 stroke, stock block motor. I have 7.1 GRP alum rods with 440 source crank and pistons. It makes great tq.
I think 4.5 X 4.5 is a good combo for us mopar guys. Good power and reliable.
My old wedge ran well, low rpm etc. It was a 4.44 bore x 4.5 stroke. deal.. It out ran several rigs at the local tracks who had twice the money in there's You think the longer arm really pays off with conventional heads, and in a power adder situation?
[Re: Bob_Coomer]
#1030010
07/11/11 11:21 PM
07/11/11 11:21 PM
Posts: 916 Arizona
Chucklehead
Arizona
I know where there is a brand new 4.5 finish bore block. It is one of the older blocks before World started to cast them.
Still Broke
[Re: Brian Hafliger]
#1030012
07/12/11 09:45 AM
07/12/11 09:45 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I can't see a reason to cut the displacement thirty cubic inches. Hooking is not a good reason to me. Make all the power you can and worry about hooking it later. I know nitrous makes good power but it will make more on a bigger motor. There is no replacement for displacement. My 540 pistons are light with the 7.1 rod.
[Re: FastmOp]
#1030013
07/12/11 02:08 PM
07/12/11 02:08 PM
Posts: 976 ontario canada
mac56
ontario canada
You have a 4.5 crank in a stock block?
[Re: FastmOp]
#1030015
07/12/11 09:46 PM
07/12/11 09:46 PM
Posts: 877 ky
68roadrunner
ky
Yes with alum rods on chevy pins.
sounds fast, how many passes you get before you have to change rod and main bearings?
[Re: 68roadrunner]
#1030016
08/10/11 01:32 PM
08/10/11 01:32 PM
Posts: 2,449 nc
earthmover
nc
