Pilot Bushing/Bearing Question #1029884
07/10/11 10:44 PM
07/10/11 10:44 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
1968 383. Here is a shot of the end of the crank. Engine is out of a B body, originally with an auto (I think).
It appears that this thing is ready to accept a pilot bearing, or am I wrong?
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029885
07/10/11 10:44 PM
07/10/11 10:44 PM
Canton, Ohio
Canton, Ohio
2
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029886
07/11/11 02:40 AM
07/11/11 02:40 AM
Measure the inside diameter and depth of the hole from the inside flat surface where you would start to slide the bushing in from, I hope that makes sense I have several crankshafts with stick shift bushing in them to look at and measure, usually the 383 crankshafts had a short pilot hole on the automatic cranks or the proper deep pilot hole for the bushing for the stick shift cranks Not like the 440 cranks that had a deeper hole and a smaller diameter on some of the automatic and the proper depth and I.D. on the stick crankshafts
Re: Pilot Bushing/Bearing Question [Re: Cab_Burge] #1029887
07/11/11 07:21 AM
07/11/11 07:21 AM
Canton, Ohio
Canton, Ohio
Okay, thanks. I can look at my 400 crank too, I guess. It is a later crank '77 I think, so I'm not sure it is going to tell me a whole lot. Might not even be drilled.
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029888
07/11/11 08:30 PM
07/11/11 08:30 PM
Canton, Ohio
Canton, Ohio
Any other 4-speed guys have anything to say?
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029889
07/11/11 08:41 PM
07/11/11 08:41 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
clean out the hole first so u can see whats going on.
Re: Pilot Bushing/Bearing Question [Re: RATTRAP] #1029890
07/11/11 08:44 PM
07/11/11 08:44 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
bushing looks to still be installed imo, fill the hole with clay use a pin thats a good snug slip fit in the hole and hammer till bushing comes out add clay as needed,
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029891
07/12/11 05:45 AM
07/12/11 05:45 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was just looking up the bushing part the other day. Here is the dimensions of the bushing:
Bushing; Bore=0.753", Outer Diameter=0.941", Width=0.88"
Rock auto has the best prices I have found for the bushings. As low as $1.23 for the Dorman #690005 upto $3.75 for the National PB286HD. Most other places are around $10?
Re: Pilot Bushing/Bearing Question [Re: 451Mopar] #1029892
07/12/11 07:31 AM
07/12/11 07:31 AM
Truckville, the capital of NY
85_Ram_4speed Offline
Andy, get the roller bearing from Mopar. It goes right in the register where the Torque Converter hub sits. Then you don't have to worry if the bushing area is fully machined to accept the bushing or not. The bearing usues a mid-late 90's Ram with a stick trans in it for an application. Been awhile, but I am pretty sure the part# is 53009180AB.
--Chad
Outcast Dodge guy.
Re: Pilot Bushing/Bearing Question [Re: 85_Ram_4speed] #1029893
07/12/11 07:39 AM
07/12/11 07:39 AM
Netherlands
72Challenger Offline
Netherlands
Yeah, what Chad said! Just measure the depth of the crank hole to be sure the input shaft doesn't bind there when installing the box. These roller pilot bushings can be gotten at Summit or Jamie Passon.
Re: Pilot Bushing/Bearing Question [Re: 72Challenger] #1029894
07/12/11 07:52 PM
07/12/11 07:52 PM
Canton, Ohio
Canton, Ohio
Thanks guys. I would rather not have to cut the input shaft, so what I have to work with appears that it won't be necessary.
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029895
07/12/11 08:00 PM
07/12/11 08:00 PM
Visalia Ca
P
prostreet68 Offline
prostreet68  Offline
P
Visalia Ca
The crank in my 400 was not bored to accept the input of the 4 speed. I took approx. 1/4" or so right off the end and beveled the end just like factory. It has full length in the pilot bearing even with the end cut off.
I also used a Dakota roller pilot bearing instead of the brass sleeve. It worked out awesome...and is in the car now.
Rick
Re: Pilot Bushing/Bearing Question [Re: prostreet68] #1029896
07/12/11 10:17 PM
07/12/11 10:17 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It looks like a bushing is in the end already, maybe its not. Why didn't you clean it up before taking the picture?
Re: Pilot Bushing/Bearing Question [Re: rowin4] #1029897
12/29/11 05:24 PM
12/29/11 05:24 PM
Canton, Ohio
Canton, Ohio
Didn't clean it cause it was on the engine stand at the time with parts piled around it. Now that I have it on blocks, there is a bushing in there already as a few of you mentioned.
I think I will go with the roller bearing. I can't see why it would hurt to leave the bushing there, so I'll probably just leave it be. Give it all a good cleaning of course.
Thanks all.
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029898
12/29/11 06:20 PM
12/29/11 06:20 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I'd remove the old bushing when using the newer roller. You don't want to chance the input snout binding in that old bushing after going thru the roller bushing. If that makes sense.
I also run the roller for the last ten years or so with no issue.
Re: Pilot Bushing/Bearing Question [Re: Crazy68Dart] #1029899
12/29/11 10:26 PM
12/29/11 10:26 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Andy I would clean it up real good with scotch brite and leave that one in there if it's like new.If it looks worn then take it out and use the bronze one that you drive into the TC register.
I use the one on the right in the picture you can get it at the Mopar dealer.
Just a heads up when you build your stroker have the crank drilled for a Mopar input,my Eagle was not drilled deep enough and I had to whack the input on my brand new Richmond box
Gus
64 Plymouth Savoy
Dana 60
Re: Pilot Bushing/Bearing Question [Re: fourgearsavoy] #1029900
12/29/11 11:23 PM
12/29/11 11:23 PM
Canton, Ohio
Canton, Ohio
Gus, thanks. I am going to do just that, clean it up real good and see if it is even worth messing with.
I didn't know there were different versions of the larger style bearing. The needles worried me a little fearing that they could be a point of failure.
Yeah, I'll need to look at the crank. It is an Ohio crank 4.15 stroke and probably not drilled. Either way, going to run the 383 for a while, but I should make a note somewhere so I don't forget.
