DMI and crank trigger #1029448
07/10/11 05:27 PM
07/10/11 05:27 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
I have the DMI low mount alternator/cranks trigger set up with a 140amp
Powermaster Alt. My problem is the motor breaks up really bad above
4500rpms. When I disconnect the belt it runs great. I shielded my pickup
Wires with 3 layers of tin foil, but that doesn't help.
My alt just died and I need to get a new one. Will a different alt work?
I know someone had this same problem like 2 years ago. How did they fix it?
Re: DMI and crank trigger [Re: Big B] #1029449
07/10/11 06:55 PM
07/10/11 06:55 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I have the same issue! I will watch this post with interest!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: DMI and crank trigger [Re: Big B] #1029450
07/10/11 08:56 PM
07/10/11 08:56 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
If they alt stopped working, just take it to a local electrical/motor shop and have it rebuilt.
Re: DMI and crank trigger [Re: Quicksilver440] #1029451
07/10/11 11:47 PM
07/10/11 11:47 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
The alt ate itself up and is not repairable. No one has any ideas?
I will probably just go back to my distributor, and sell the DMI/ crank teigger setup if I can't fix this.
Re: DMI and crank trigger [Re: Big B] #1029452
07/11/11 12:04 AM
07/11/11 12:04 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
forget the foil Did you twist the wires like instructed
Twist the wires of the pickup together several times before connecting it to the MSD wiring harness. Twisting these wires together helps reduce the chances of Electro Magnetic Interference (EMI ).
Route the pickup harness along the chassis or engine block. This provides a ground plane that protects against EMI.
Do not run the trigger wires along the coil primary wiring or spark plug wires. There are high voltages running through these wires so they should not be close to the pickup wires.
Never use solid core spark plug wires with an MSD Ignition system or crank trigger. A helically or spiral wound suppression wire such as MSD’s Heli-Core or 8.5mm Super Conductor Wire must be used.
If you are running a digital ignition control or aftermarket EFI system, it is highly recommended to use a shielded harness, PN 8862, to prevent the chance of EMI interfering with the trigger signal
home of the
Sox and Martin Hemi Duster
Re: DMI and crank trigger [Re: HEMIFRED] #1029453
07/11/11 08:19 AM
07/11/11 08:19 AM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
Actually I didn't twist the wires off the trigger sensor.
Hopefully when I replace the alt that will fix it.
I might buy a shielded cable too, since the tin foil looks like crap.
Would a MSD noise filter do anything?
Re: DMI and crank trigger [Re: Big B] #1029454
07/11/11 03:12 PM
07/11/11 03:12 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Can you just move the pick-up to the other side of the motor?
Re: DMI and crank trigger [Re: HardcoreB] #1029455
07/11/11 05:30 PM
07/11/11 05:30 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
The oil filter is in the way. Would have to buy a remote oil filter kit.
Hopefully I won't have to do that.
