440source water pump housing combo
#1029150
07/10/11 02:30 AM
07/10/11 02:30 AM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
Am thinking of purchasing this housing with pump to replace my iron junk.Are these as good as the stuff offered by others for quite a bit more.
99 bucks from the source,anybody run these peices??Thanks so much
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
Re: 440source water pump housing combo
[Re: Kam*Kuda]
#1029159
07/10/11 05:57 PM
07/10/11 05:57 PM
451 D*O*D*G*E
Hr up from KCK
Sounds like a lemon 1 in a 1000 to small or casting flash,excess metal??Did he return it or band saw it to see the issue?
[Re: 451 D*O*D*G*E]
#1029160
07/10/11 06:12 PM
07/10/11 06:12 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The 440S water pump housings got a really bad rap when some of them had restricted ports that contributed to heating issues.
Do a search for it on Moparts and you will find many separate bash-fests.
[Re: feets]
#1029161
07/10/11 06:16 PM
07/10/11 06:16 PM
451 D*O*D*G*E
Hr up from KCK
So was this told to the 440source?What would be the chance of buying a current new one from them doing this?
[Re: 451 D*O*D*G*E]
#1029162
07/10/11 06:22 PM
07/10/11 06:22 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I ran the housing and pump for a while. Engine got hotter than it used to if it idled for a while. I swapped the pump for a stock type iron pump and it ran cool again at idle. The pump is an odd design, the blades are cast into it and are very shallow, worked well as long as the car was moving but got hot in traffic. The housing gets slated for being restricted but my car runs cool, even in the summer, so I don't think the housing is the problem.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#1029163
07/10/11 06:37 PM
07/10/11 06:37 PM
451 D*O*D*G*E
Hr up from KCK
Interesting,can anyboody disprove what Mick said?Thanks Mick.
[Re: 62maxwgn]
#1029165
07/10/11 06:55 PM
07/10/11 06:55 PM
451 D*O*D*G*E
Hr up from KCK
By reading through all that the housing that are new current peicies are a two finger affair.Shallow vains?,,whole deal sounds like a crap shoot.
[Re: 451 D*O*D*G*E]
#1029166
07/10/11 10:27 PM
07/10/11 10:27 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I run one on my 512RB 4spd 70 Charger RT with the Source WP housing but a stock type WP because the source WP had clearance issues with my billet pulleys. Aftermarket aluminum radiator with no shroud and it never gets over 195 degrees in stop and go traffic and it was 105 degrees yesterday when crusing around town. I will be getting a shroud anyways.
