318 just bogs out when I hit the gas #1028967
07/09/11 05:59 PM
07/09/11 05:59 PM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
Ive tried about everything I can thik of new tune up rebuilt carb and set timing, I need some back yard tips ongetting this to run right, please!! Thanks
Re: 318 just bogs out when I hit the gas [Re: 67Mopar] #1028968
07/09/11 06:03 PM
07/09/11 06:03 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
need way more info, is it stock 2 bbl, did you modify it? timing should be 8 10 initial with 35 total or so, and the accelerator pump needs to sqirt gas the instant you touch the gas pedal (maybe even a hair before you touch the pedal LOL)
Re: 318 just bogs out when I hit the gas [Re: 67Mopar] #1028969
07/09/11 06:37 PM
07/09/11 06:37 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Check for a vacuum leak.
Re: 318 just bogs out when I hit the gas [Re: 67Mopar] #1028970
07/09/11 06:52 PM
07/09/11 06:52 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
please, some more info. what car is it in? what manifold and carb set up are you running? where's the timing set? what gearing are you running?
