A body lower control arms #1028686
07/09/11 02:14 AM
07/09/11 02:14 AM
Sturgis S.D.
tripleblackcuda Offline OP
Sturgis S.D.
Will any other car or truck's lower control arms fit a 74 Dart? Does anyone make new upper and lower control arms for a 74 Dart? Any help would be appeciated!
Re: A body lower control arms [Re: tripleblackcuda] #1028687
07/09/11 10:44 AM
07/09/11 10:44 AM
E body ones (& prob others) will physically fit but unless your circle track racing will b too short (camber) so no on that one. No new ones avail AFAIK stock. It's a non wearing item so might search on here for some & press in new bushings/screw in ball joints & You're good to go EDIT can cut the bracket/press it closer/reweld & elim alot of OE play & b better than new (LCA)
Re: A body lower control arms [Re: tripleblackcuda] #1028688
07/09/11 11:53 AM
07/09/11 11:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does your car have a FACTORY swaybar? if yes then you need to find a control arm from a 73 -76 A body , if not the arm from a 67 up till 76 will work.
For the upper arm you need one from a 73-76 A body.
If you don't care if the arms do no look like the stock arms there are aftermarket tubular arms available .
Re: A body lower control arms [Re: JohnRR] #1028689
07/09/11 07:50 PM
07/09/11 07:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
In 1973 when the A body cars were first available with the large bolt pattern and front disc brakes, the upper control arm was redesigned and used the larger ball joints shared with the B and E body cars. The cars with 10 inch front drums also used the redesigned upper control arm. There WERE also a few cars built with 9 inch drum brakes that still used the same upper A arm as in all previous years. This arm used the small ball joint and will not work with a 73 and later disc knuckle. I have read of a few companies that are reproducing the upper control arms. I seem to recall Magnum Force racing? Not quite sure. CAP products makes new lower arms.
The B and E lowers used a different pivot shaft with a larger diameter and a "step" that keeps them from being a direct fit. I'd guess that if you changed out the pivot shafts, they would fit, but they are also supposed to be shorter from the pivot shaft to lower ball joint, so this would certainly make aligning the car an interesting situation....
