Re: 650 Eddy or 670 Holley
[Re: DAYCLONA]
#1028665
07/09/11 11:06 AM
07/09/11 11:06 AM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
Go with the Holley, I've run 2 Avengers on 2 different motors, very tunable, responsive, trouble free carbs,....the EDDY is best left in the junk pile, because it will end up there sooner or later
X2
[Re: 13ChargerR/T AWD]
#1028671
07/11/11 11:57 PM
07/11/11 11:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
probably got part of the bad batch..as to why people think they are junk
Must of been quite a huge "batch"......I've been tossing those Eddies since the mid 90's to present off customers, and friends cars,......while the old Carter AFB/AVS were great carbs, the Eddy can't compare, from casting flash floating around in the carbs, to just poor castings, poor machining, assembly, etc,....the Eddys are just pure headaches for reliability,....performance wise they just don't compare to a Holley,.. I've reworked/machined a few Eddys, the amount of work needed to bring them up to a box stock Holley isn't worth it IMHO..
[Re: VITC_GTX]
#1028674
07/12/11 12:11 PM
07/12/11 12:11 PM
Posts: 277 Cincinnati, Ohio
chargincharles
Cincinnati, Ohio
I've run AVS's on almost everything I've ever built (Small blocks, Big Blocks, even an old 2.2 4cyl that I wanted to see if I could run with one) and never had any issues with them. The trick is to get yourself a REAL Carter AVS. Pick one up off of eBay, Craigslist, or swap meet. With a 383, get one that originally was on a 440 for a little extra CFM. The currently 'Thunder Series' Eddy AVS has a tuning kit available that is completely compatible with the old AVS's. And rebuild kits are available nearly anywhere (Rock Auto, Napa, Pep Boys, Advanced Auto, Etc.) I've heard good and bad about the Eddy version, but the cost is what keeps me from buying one and trying it. $ for $ though I find it hard to justify the added complexity in both the Carb and the tuning of a Holley. Not when I can swap rods out of a AVS in under 2 minutes. And with no gaskets below fuel level, you will never have the issues with fuel leaks like I've seen in soooooo many Holleys. I can pull the top and have the jets swapped inside of 10 minutes- on the car, and you adjust the air door of the AVS secondaries with a pair of screwdrivers! Just a much much simpler carb to deal with.
I'm sure many people have had great success with Holleys as well. So really it comes down to what you know and how much you are willing to learn. Presonally, I'm looking to put a Predator P6000XI on my next project. One Biiiiiggggg venturi. Great carb if you have the hood clearance.
Just my pennies, CC.
[Re: VITC_GTX]
#1028676
07/12/11 02:04 PM
07/12/11 02:04 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Essentially stock 383. What carb do you like best for power/fuel mileage balance, 650 Thunder Series or 670 Avenger?
I am running a 650 on a 318. I am thinking you need a bigger Holley or Eddie for your engine for optimum performance. There are calculators around to help you out on what you need. One is here: http://www.4secondsflat.com/Carb_CFM_Calculator.html Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
