The 22 lb is more of a racing app so it'll withstand a higher temp b 4 it boils and pukes. You'll prob not get near those temps; boiling point 212 deg F (pure water at sea level) & I think antifreeze lowers it a bit but not sure + the cap raises it 22 times ~3 deg b 4 it opens and if you have/want a recovery cap/bottle you want a lower (the std 16lb) cap so it'll purge the air out which lowers temps slightly (elims air pockets)/inhibits rust (less air (oxygen) in the system) otherwise either a 16 or the 22 will work fine, just keep your temps in the normal range EDIT actually I think antifr raises it a bit
